R50/53 Dealer forgot to add the $100 rear fog light
Old 01-03-2006 | 08:27 PM
LombardStreet's Avatar
LombardStreet
Moderator
Originally Posted by Crashton
I think it all depends on the build date of your car. If it's a recent build there should be no problem retofitting the rear fog. Your dealer parts man should be able to tell by using your VIN number if it's just a plug & play on your car.
That's correct. My car is an early '05 model with a 10/04 build date. I think the cut-off date was 10/14/04. My car just narrowly made it. Mine had the wiring all in place.
There's a gap from - what? July? - '04 through mid-October '04 where the cars had the bumper-mounted foglight socket but didn't have the wiring harness in place. Those cars in that three-or-so month period have an expensive (or complicated DIY) retrofit. Earlier cars have the fogs in the taillight assemblies. Later cars have the wiring in place for the bumper-mounted foglight.
I ordered my light and the toggle switches from Brian at Classic MINI in Ohio, one of NAM's vendors. They used to offer a 20% discount on parts to NAM members. (Do they still?) I seem to recall it came to less than $100, including shipping. It's easy to install yourself. Info can be found in the "2005 Rear Fog Retrofit" thread:
https://www.northamericanmotoring.co...ad.php?t=35546
See especially my post, #17 in the thread, which has pics of the harness.
Note that once you've installed everything, you still need to take it to the dealer and have them activate it. Some dealers charge an hour, some charge a half hour. Be sure to think of anything else you want them to change in your car's programming while they're activating the fogs - things like automatic door locks, daytime running lights, "guide me home" headlights, etc.
(Sorry for two long-winded posts in a row. I'm pretty passionate about fog lights!)
  #27
Old 01-04-2006 | 08:44 AM
MCDriver's Avatar
MCDriver
can it be wired to illuminate only as a brake light when the brake is applied?
  #28
Old 01-04-2006 | 08:59 AM
OldRick's Avatar
OldRick
You can wire it to act as a brake light.
  #29
Old 01-04-2006 | 09:26 AM
MR ECON's Avatar
MR ECON
I agree that the rear fog light is a safety feature. Since I live in snow country and drive in the Central Valley of California quite often, I wouldn't be without it. Someone asked me what good it was since I couldn't really see well behind me in snow/fog anyway, and I had to point out that it was more for others to see me. Anyway, I think it was a good $100 investment. Better even than 40 lattes.
  #30
Old 01-04-2006 | 09:43 AM
asaulo1's Avatar
asaulo1
Thanks for the link.... I've been looking to put an OEM looking 4th brake light...
Originally Posted by OldRick
The rear fog lamp is pretty useless as a fog lamp anyway.
Instead, spend $20 and get the OEM light, wired up as a third backup light or a fourth brake light ($38) - your choice:
MyMiniParts Backup light
Your 2006 is pre-wired, and installation takes about 10 minutes.
  #31
Old 01-04-2006 | 09:44 AM
LombardStreet
Moderator
Exactly - it's so that big rig can be a lot farther behind you.
07-16-2020 12:54 PM
Wohnson89
06-10-2020 04:53 AM
12-23-2015 10:36 AM
wkp1219
11-13-2015 07:52 AM
08-07-2015 08:02 AM
Quick Reply: R50/53 Dealer forgot to add the $100 rear fog light
