R50/53 How long did your original brakes last?
Hi, I just came back from Mini dealer and amongs other things they checked my brakes. Pads were at 8mm. I know they replace them at 3mm. I am at 20k miles. I will probably not see a free brake replacement before 36k maintenance runs out.....
I can extende maintenance till 4/50k for $400 - is it worth it?
If I can get a set of rotors/pads I guess it would be.......what do you guys think?
Also, inpection II is at 60k, right?
Thanks!
Thanks!
I got 70,000 out of the OEM brakes on my first MINI. Just replaced the brake lines, rotors and pads. Went with PowerSlot rotors and Hawk ceramic pads. I really like the new system. Very little brake dust. I have 38,000 on my second MINI so far. The OEM pads and rotors are designed to wear together so you may be replacing the pads and rotors at the same time.
Don
Don
Originally Posted by gandini
My OEM pads lasted about 1000 miles, before I replaced them with Hawk ceramics! Extremely little brake dust and at worst as good braking as before, but mostly better with equal or better pad life.
cheers,
phil
cheers,
phil
Chuck
My front brake pads and rotors lasted almost 40k miles. I had them replaced by my local independent BMW/MINI mechanic.
My rear brakes have been my problem. The right rear went down to metal on metal at abour 24k miles while the left still had about 1/3 pad left. They were replaced under warranty. Recently, the identical situation occurred after another 24k miles and they are now replacing the right caliper and replacing pads and rotors under warranty due to the unusual wear pattern.
I expect that the original rear pads and rotors would have lasted about the same 40k miles had my MINI not had this issue.
(another YuccaPatrol post accidentally posted under his wife's account! :impatient )
Yucca, that was my problem which caused the light to come on during the trip to MOTD 2004. After that I never had a problem with them up until selling the car at 46k miles.
I'm suprised at this set going bad so soon. Squeeking like a mad man and tonight, slowing and turning sharp into a parking space, an awful sound and vibration similiar to a CV joint going bad. I'm thinking something loose in the braking system but after checking when I got home nothing seemed out of place.
