R50/53 Wheel offset that fits MINI
Hi, what wheel offset can use on the Mini?
I know stock rims are
15x5.5 with 45 mm offset
16x6.5 with 50 mm offset
17x7 with 50 mm offset
Can I use 16x6.5 with 45 mm offset?
I see a lot of Acura/honda rims that are cheap and would be nice for a winter package...thanks
All of the below will fit, considering 195-215 size tire widths.
I am currently using 16x7.5" +42mm offset running 205/50/16 performance
tires.
The other important thing to remember is the 4x100 PCD (bolt pattern)
and 56.1mm center bore. Most Honda civic and Integra wheels will
fit given the above bolt pattern and center bore.
tires.
Ive seen people use +38..if you use 195/55/16's you probably won't rub,
but any wider might rub the rear.
check out the tires&brakes forum and we can get you more details on
how to do the dremel trick. :smile: minihune can tell you all about the tricks
he knows and his garage full of tires and wheels and more tires and wheels.
SosoMINI
11-22-2015 03:17 PM
Mini'mon
08-16-2015 04:15 PM
08-07-2015 05:55 AM
