R50/53 Dorky cheapskate modification
#454
#455
#457
#460
taped off the valve stem with some masking tape, poped out the center cap..sanded it lightly with 600 grit sand paper cleaned throughly with some windex, picked up some appliance paint/epoxy for 7.99 at the local hardware store. sprayed it in a thick base coat follwed by another thin coat, sprayed some cheapo spray clear coat once it was dry and wah lah.
appliance paint is key because the white wont look dull and its less likely to chip since it is an epoxy.
white s-lites are ****, i wish my car had came with them from the factory, but these came out looking factory smooth and shiney..a few small blemishs from the old curb rash but they are just for the winter so who cares
#465
Well, I am catching on to the idea. I plastidipped the grey outside part of the tac yesterday. i like it. wife does not. also black vinyl over the orange and red side markers. i like it. plasti dipped the a/c rings and the speedo but took it off the speedo, it was kind of bubbly. also put some cork board i had from an old dart board under the plastic boot deal for sound. it's not real loud. hello.
i want to try and vinyl wrap my hl rings in pw and also considering trying to vinyl pw the 3 piece dash..and perhaps door parts down the road.. anyone done that? i could use some help on the vinyl but i am getting the idea from other sites.
does anyone know if the headlights should be removed to do the vinyl??? ty
#469
#470
New cheapskate mods
I closed in the airbox with aluminium plate after installing the K&N Typhoon, then extended the "front" air intake with a silicone 45 bend and hose clamp. Finished it off with a little foam door seal along the top edge. Cost- maybe $20 total.
I made the radiator air diverter from a rubbermaid cuttlery tray with some fancy cutting and sanding for a perfect fit. The intent is to force more air up into the above mentioned airbox pipe. Cost-$3
The door bin lights were made from motorcycle light pods. They are clusters of coloured LEDs mounted in a chrome housing. Mounted with 3M double sided trim tape and wired in to the footwell lights which also have green LEDs in them. This was pushing the budget at $16 cost.
Andy
Andy
#473
So you're redirecting air from the radiator to feed the intake? Are you checking your H20 temps? Seems that could be an issue in hotter weather.
#475
I was gonna do this same thing with diamond plate but that stuff's expensive. I used a sheet of stainless steel (6"x12", $7.99) and bent it a couple times to fit perfectly on the top of the stock airbox. I used a couple self tapping screws, a piece of PVC hose (2ft@$1.39) split down the middle and laid on top. $10 and a sliced finger later, it's all good.
