R50/53 Dorky cheapskate modification
Old 06-12-2011, 12:39 PM
joe_bfstplk's Avatar
joe_bfstplk
joe_bfstplk is offline
Originally Posted by JumpingJackFlash
OK, I'm gonna contribute one photo for this thread. I removed the cup holder on the right pillar and mounted my Sirius Satellite radio on it early last year. Used a 3-4" threaded shaft, three nuts, and a small piece of sheet steel bent at a 90-degree angle.
Nice. I'm thinking of doing something vaguely similar behind the tach for my phone....
C ya,
Dutch
  #527
Old 07-04-2011, 03:29 PM
SpyVsSpy's Avatar
SpyVsSpy
SpyVsSpy is offline
Thanks to all for showing me little tricks to change the badge on my Mini Cooper. Like so many others, I want to make my Cooper S a little different.
$ 0.00 - Removing Cooper S Badge
$ 8.00 - R badge
$29.00 - 56 badge
Priceless - making my Cooper a little different
  #528
Old 07-23-2011, 09:41 PM
msjulie33's Avatar
msjulie33
msjulie33 is offline
rattle fix
My cheapskate fix - i had a rattle in the car when driving over grooved pavement which drove me nuts. Turns out the pass side downtube (?) was ever so slightly loose and would buzz against the bottom of the console. Whomever installed the cup holder totally bugged up the lower fastener so tightening it was a no go.. Used a screw driver and gently wedged the lower console away from the downtube so I could squeeze just a little goop in the space (it's like stronger rubber cement) to kinda make a gasket. Now the downtube is all snug and no rattle. It's the little things..
The arrow shows where the goop got squeezed into, kinda; Be really gentle making the gap to squeeze in the goop
fyi not my car in the pick, that one has no cup holder...but it was the perfect angle shot
  #529
Old 07-26-2011, 04:05 AM
DixonL2's Avatar
DixonL2
DixonL2 is offline
I did the same thing, but with adhesive-backed black crafters' felt... $0.98/sheet!
  #530
Old 07-26-2011, 12:17 PM
u68423's Avatar
u68423
u68423 is offline
Did this last year
R-FREE just some sanding and paint
53 - 12.00 carbon fiber look
Questions I get priceless.............
$ 8.00 - R badge
$29.00 - 56 badge
Attachment 54332
Attachment 54334
  #531
Old 07-26-2011, 08:18 PM
DixonL2's Avatar
DixonL2
DixonL2 is offline
JumpinJackFlash, are those circles on your dash part of a sidewalk package, or are they decals you put on? Either way, cool.
  #532
Old 07-26-2011, 08:34 PM
JumpingJackFlash's Avatar
JumpingJackFlash
JumpingJackFlash is offline
DixonL2, to my best knowledge, those circles were part of the Interior Surface Seven package, which was one of the ones that came with this MINI when it was originally delivered (I bought it used). This includes the black dash and two large door rings. Guess the small circles are just something to help take up the large panel so it's not so plain looking. Since the airbag is actually in the top of the dash, some sort of LCD swapout would not be too bad of an idea either.
  #533
Old 09-17-2011, 06:58 AM
mini coop's Avatar
mini coop
mini coop is offline
Magnetic stone guards---bought magnetic signs at Lowes in the sign department that say "For Sale" on them. You get two for about ten dollars. Cut them to the shape of the stone guard that I wanted and then painted them flat black. I have had them on my car for over year and they look great. I touch them up with paint once a year. The OEM guards are expensive, very thin and very cheaply made. These are very thick and sturdy. I am very happy with the results.
  #534
Old 09-17-2011, 07:21 AM
ngweibing's Avatar
ngweibing
ngweibing is offline
hey... any pics? i can't find them at local lowe
  #535
Old 09-17-2011, 07:35 PM
mini coop's Avatar
mini coop
Magnetic Guards from Lowes Magnetic "For Sale" sign
Here are what the guards look like after cutting (with scissors) to the shape that I wanted. I then painted them flat black. The magnetic strength is very good. The sheet is big enough that they can be bigger if you want.
Attached Thumbnails Dorky cheapskate modification-cid__downsized_0901111708.jpg
  #536
Old 09-19-2011, 06:11 AM
rod from maryland's Avatar
rod from maryland
rod from maryland is offline
i guess i fall into the catagory of "mcgiverism, cheep, innovative, cheep, creative, cheep....
my 03 mini was a commuter car before it came into my garage ,,one of the biggest things that drove me nuts was the scratches in the center of the steering wheel, and the silver ring looking really poor...
since there werent any real options available, i decided to play w it
I found that some careful prying got the center off..i did find that the mini wing is part of the thin metal that makes up the center insert, and no matter of paint would cover it completely...sooo...
in the end, i carefully sanded off the silver ring until it was all black...using a piece of black wire, i made a thin trim along the outside egde of the ring
for the center, i brainstormed for days about something that would be the right diameter...in the end, and dont laugh too much, i found that the bottom of my dodge nitros cup holder had this round foam piece that fit perfect..attached it to the removeable center, reintalled it, and ran a smaller gray ( silver) wire around that
in the end, a few drops of super glue, a half sheet of sandpaper , and a few hrs of work/thinking, etc...
the result
  #537
Old 09-19-2011, 03:52 PM
SWAgoat's Avatar
SWAgoat
SWAgoat is offline
I just found this thread a few days ago. I have gotten a few great ideas. Subscribed!!
  #538
Old 09-19-2011, 07:06 PM
IQRaceworks's Avatar
IQRaceworks
IQRaceworks is offline
Originally Posted by steelz21
I closed in the airbox with aluminium plate after installing the K&N Typhoon, then extended the "front" air intake with a silicone 45 bend and hose clamp. Finished it off with a little foam door seal along the top edge. Cost- maybe $20 total.
I made the radiator air diverter from a rubbermaid cuttlery tray with some fancy cutting and sanding for a perfect fit. The intent is to force more air up into the above mentioned airbox pipe. Cost-$3
The door bin lights were made from motorcycle light pods. They are clusters of coloured LEDs mounted in a chrome housing. Mounted with 3M double sided trim tape and wired in to the footwell lights which also have green LEDs in them. This was pushing the budget at $16 cost.
Andy
How did you hook up the LED's you put in the door to light up when the interior lights do? What wire did you tap into?
Thanks!!
  #539
Old 10-06-2011, 07:22 PM
kb30's Avatar
kb30
kb30 is offline
i think im gonna do the garage door front lip. I might try to give it a spray with some leftover krylon textured paint that i touched up my grill with.But not too much that it would give a cracked look when it bends but see if i can get it to blend better with the trim on the mini. it'll be something interesting to try when im bored...
  #540
Old 10-06-2011, 07:31 PM
LAMARR -s53's Avatar
LAMARR -s53
LAMARR -s53 is offline
I just did that to mine last week !! Looks nice and easy ! I posted a thread on it. Couple weeks ago
  #541
Old 10-06-2011, 10:55 PM
89AKurt's Avatar
89AKurt
89AKurt is offline
Hey, I'm thrilled this thread is still popular!
  #542
Old 10-07-2011, 08:34 AM
Kirby11's Avatar
Kirby11
Kirby11 is offline
Are you kidding? This thread is awesome! I only wish it were out in the general section... Some of us R56 owners are dorky and cheap too!
  #543
Old 10-08-2011, 06:25 PM
Brisby's Avatar
Brisby
Brisby is offline
D'OMG, I love this thread!
Being that I just recently purchased my R53, I'm a wee bit light on modification funds. Perfect for this thread right? Anyway, enjoy my cheapskate mods! Here's what I've done so far:
1 ) My door pull handles were a little scratched up (previous owner must have liked wearing rings) and I happened to have a ton of extra tennis racquet wrap laying around, so this happened:
I actually rather like it. I use sponge-like wrap, which makes these handles rather comfortable now. Anyway, it's a good fix until I get some leather door pull covers. I wouldn't recommend the thin tape-like wrap.
2 ) While I was messing around with the door pull handles, I also threw some wrap on my downtubes. It's a very cushy wrap, so resting or bumping your leg against the downtube is now more comfy. This is good for now, but I will be trying the plasti-dip or leather covers later on.
3 ) I was going a little crazy trying to find a small box or two to fill the vacant spaces in my center console area. Come to discover, my iPhone 4 box was a perfect fit! The box is in two parts, a bottom piece and a top piece that fits over the top. I stuck some soft red velvet to the inside of each, double-sided tape to the surfaces meeting the floor, put the top piece in the space ahead of the cup holders, and the bottom piece in the space under the E-Brake handle (note: the box is the perfect height as well! Does not interfere with the E-Brake operation at all):
I also used the little plastic plate that held the iPhone in the box as a divider for my make-shift change holder. I can't get over how well this works! lol
4 ) I saw someone online selling a decal for spicing up the center dash, and decided to try making one myself. Instead of a decal, I printed out my Mini's Electric Blue color onto photo paper. Then I took off the trim pieces on the center dash (hazard lights, center gauge, and brightness trim pulls straight off - the air duct trim pieces need to be turned clockwise about 1/4 of an inch then pulled straight off). I carefully drew the layout freehand, then used a compass to get the curves right. I kept my template a little larger than what I actually needed, so that I could make adjustments with a pair of scissors as I went. It did take awhile, but eventually I got every edge flush. I didn't use any kind of adhesive, since the trim pieces hold the paper firmly in place. Now that it's there, I most likely won't stay with the photo paper blue (it's too shiny), but I'm not sure exactly what I'm going to go with next. I can cut in just about anything now that I have the exact template. My girlfriend suggested picking up an old tweed sport jacket and using that. Guess we'll have to go shopping, heh. oh, I also used double-sided tape and cut in a piece to go in between the tach and the speedometer.
5 ) And for my next trick, I have something very cheap! I want to put in colored LED lights for my overhead and accent lights, buuuut I won't be able to for a little while. In the meantime, I simply pulled out the bulbs, colored them with a blue wedge-tipped Sharpie, and carefully put them back into place. The effect is spot on! Sure they are not as bright as LED lights, but they do the job. I left the reading lights clear, just in case. I don't have pics of this atm, but I love the look.
  #544
Old 10-09-2011, 06:42 PM
DixonL2's Avatar
DixonL2
DixonL2 is offline
LOVING the tweed jacket idea...
  #545
Old 10-09-2011, 07:24 PM
chaswyck's Avatar
chaswyck
chaswyck is offline
This is NOT me and this is NOT my car, but I saw this on YouTube and I couldn't stop laughing. When you look up ghetto on dictionary.com, there is a picture of this armrest. I especially like the hinges. LMAO And, dude, if you're on NAM and you see this post, my apologies in advance, but I couldn't resist. You did save a couple of hundred dollars, though!
http://www.youtube.com/watch?v=fAe4t3ypHI0
  #546
Old 10-10-2011, 12:24 PM
Gil-galad's Avatar
Gil-galad
Gil-galad is offline
"She may not be very pretty now, but she was somebody's baby once..." (Bugs Bunny, circa 1956)
  #547
Old 10-10-2011, 05:28 PM
chaswyck's Avatar
chaswyck
chaswyck is offline
I wasn't putting down his car, I was commenting on that awesome armrest. It doesn't get much more "dorky and cheapskate" than that. LOL
  #548
Old 10-10-2011, 10:03 PM
LAMARR -s53
Hey whatever works. Lol
  #549
Old 10-12-2011, 10:00 AM
RGCOOPER's Avatar
RGCOOPER
RGCOOPER is offline
Wow! MINI Wilson Addition-
How about a tennis racket webbing roof graphic?
  #550
Old 10-12-2011, 02:24 PM
Brisby's Avatar
Brisby
Brisby is offline
Lol, Before I found Brisby, I was seriously looking at a yellow MCS with plans to add black stripes and the vanity plate, "10S BALL".
Quick Reply: R50/53 Dorky cheapskate modification
