R50/53 New Noise
Old 03-10-2006 | 03:47 PM
andromcs's Avatar
andromcs
Originally Posted by plantain
I think have a rather similar sound - dull kind of knocking, but it's very regular, almost like a "burble". With the hood up, I can't hear it very well with the car engine running, so I don't think it's actually in the engine compartment. It sounds sort of like it's coming from over the dash, but I'm not positive.
If you've made any progress, I'd be curious.
Plantain,
Your description is similar to the sound I heard. I could hear it with the hood up...on the passenger side. Again, the sound is gone and it was in an instant. I have no good clue what it was. It did start right after my first free service....makes me think the mechanic left a socket or something that I couldn't find and it rattled or knocked against something until it got dislodged and either fell-out or is lodged better now!
  #27
Old 03-10-2006 | 03:50 PM
BLIZZ's Avatar
BLIZZ
Originally Posted by andromcs
OK....I scheduled an appointment at the dealer to let them fix the knocking. Couldn't get an appointment for two weeks plus!...but yesterday...I went around a sharp corner and there was this noise like a rock loosening from a tire and hitting the wheel-well and low and behold...no more knocking! The sound is gone. I definitely am enjoying just the normal sound of our MCS. Of course I am continuing to wonder what caused the noise and where the source might be now...did it get thrown from the car or is it just lodged somewhere to loosen and reappear later???
I have seen many times where a rock gets lodged between the backing plate & brake caliper/rotor....makes a noise like you decribled. Also used to see the same thing in wheel hub caps.
I would say that your noise is gone never to return.....unless you drive on a gravel driveway.
  #28
Old 03-11-2006 | 09:43 AM
plantain's Avatar
plantain
Plantain,
Well, I hadn't driven the car in 2 days, so when I drove it last night for the first time, I was rather surprised to hear the sound had completely gone. However, after about 30 minutes, I started to hear it again, but now it's more "muffled" sounding. My theory is that it's something related to one of the belts not getting lubricated. It doesn't come and go suddenly - it tends to "ramp up" in volume over several minutes.
Well, I've only been in for my first oil change 7K miles ago, so I'm quite certain it's not something that my dealer did.
Actually, one of my first thoughts was that it kind of sounded like a pump rattling with less fluid in it - I thought maybe I was low on something, but I've checked all the reservoirs and they are at their normal spots.
  #29
Old 03-11-2006 | 11:19 AM
Barnabas's Avatar
Barnabas
Yep sounds like a vibration damper. As for putting the microfilter cover on. The 4 tabs just snap in, no screws required.
  #30
Old 03-11-2006 | 05:45 PM
plantain's Avatar
plantain
Originally Posted by planeguy
Look at your motor mounts...Do a search on here to find picks of seeping motor mounts
Not sure who this was for, but I did check out the passenger side motor mount and didn't see any liquid seeping like the other guy who posted pictures of this.
We're having a bit of cold rainy weather (yeah, still mild by the rest of the country's standards but unusual for this car) and I've noticed the sound has gone away on its own. I will be monitoring it closely to see if it comes back.
  #31
Old 05-14-2006 | 09:07 PM
british kompressor's Avatar
british kompressor
has someone ever found the solution to this? I have the exact same sound... its freaking anoying!
BlueMiniac (09-15-2019)
  #32
Old 05-15-2006 | 09:06 AM
Archanum
Guest
Posts: n/a
I definately have a similar sound, and it definately sounds like a vibrational sound. So, I would think something mount related would be the issue. I had my car in once to get it fixed and needless to say the "fix" didnt actually fix it. I think I am going to bring it in again at my service 1 and tell them its still there. I think the suggestion that Barnabas had about it being a vibration dampener is probabaly right. Now if we could only get a dealer to confirm it.
  #33
Old 05-26-2006 | 08:59 PM
british kompressor
I cant beleive no one knows what this is...
I inspected the dampers and they look fine. I would hate to take the car in for a really simple problem.
  #34
Old 09-13-2019 | 08:46 AM
BlueMiniac's Avatar
BlueMiniac
Knocking 3 times in glove box. R57 2009 mcs
Help me determine what’s wrong with my mini!! Just the other day I started it (cold) and it gave me 3 large knocks (like something was in there!! Is it a gnome?!) I was surprised by that. Then it happened again 3 days later while driving at slow speed. Front right, sounds like it’s in the glove box. Any ideas???
she has 100k miles on her
Last edited by BlueMiniac; 09-15-2019 at 05:48 PM. Reason: Still happening. Now have check engine light.
  #35
Old 09-15-2019 | 05:39 PM
pnwR53S's Avatar
pnwR53S
6th Gear - NAM Hall of Fame
OP last post in 2008. You know a lot of folks change cars more frequently than I do my underwear.
I make unscheduled change though if I crap at the track due to unplanned spin at high speed near misses.
  #36
Old 09-16-2019 | 06:31 AM
BlueMiniac's Avatar
BlueMiniac
Um, thanks? This answer makes absolutely no sense to me at all. Please explain, if relevant, which I think it not.
Its important to me to get an idea of what’s wrong, took Mini to get check engine scan and got ZERO codes. Still have CHECK ENGINE light and knocking noise. This isn’t over.
TrueEddie
08-23-2011 12:00 PM
lacning74
07-23-2007 10:36 AM
PuppetMaster2u
09-22-2006 08:34 PM
PuppetMaster2u
09-21-2006 05:32 AM
Quick Reply: R50/53 New Noise
