R50/53 Things You Didn't Know About Your MINI
#376
Coordinator :: STLMini
on
Originally Posted by tattman23
LOL, I admit it took me more than one soaking, to thoroughly learn that. When it's wet after a rain, leave the sunroof CLOSED for the first half a mile or so . The roof is smaller than the beltline, too, so water doesn't fall down, it falls IN thru the open windows!
Or before takeoff, break out the nice soft microfiber towel (that's in the boot for just such an emergency), and blot up 90% of the water that would otherwise end up all over you (and the interior ) . If you soak it up beforehand, all the better to deal with "steamy" conditions where you want to open up the car BEFORE you drive off.
Tatt
Tatt
#378
Originally Posted by umberto
I just found out, after a brief but heavy rain, that after a rain storm, when you go out to your car and start it and open the windows because it is hot and steamy out, and then you start to drive off and immediately start to turn to the right and stop....that all the standing water on the roof of the car rolls off the roof and comes through your open window in a wave of water that rushes into the car and all over your right leg
The climate controlled glove box is a great place to keep you chocolate bar! I wonder if I could keep my glass bottled cokes in there? (of course, only with the AC on )
#380
I didn't know that they changed how and when the Xenon lights self-leveled in the '06 MINIs.
My '02 MCS Xenons self-leveled visably every time that you turned on the lights. You got this really cool little light show as the bulbs flickered awake, changing color as the bulbs came up to temperature, and then dipped to their lowest setting and then came back up to the propper level.
My '06 MCS Xenons do not do the same thing and leave me quite disappointed as I rather enjoyed the light show. It seems as though what they have done is have the lights self-level as soon as the engine starts regardless of whethter or not the lights are on. So unless you have the light switch turned on before you start the engine you do not get to see the light show.
Heck, if I knew that they changed it I probably would not have gotten the Xenons.
#382
Originally Posted by MINICHEF
Found This Out While Driving Through Yosemite And Sequoia National Parks. The Cruise Control Will Not Work Until You Are In At Least Third Gear.
#383
Originally Posted by cindy2627
I just got rid of my BMW 740iL and had the ez pass on the front license plate holder. I just took it off and put it on DaMini. Can't even notice it!
Tatt
#384
I thought whether it worked it or not was determined by speed (above 35 or something)... I suppose the way that I drive, above 35 = 3rd gear. You might try winding out 2nd a bit and seeing if you can get cruise to go active.
#385
#386
Originally Posted by trbasil
I've got one that nobody has mentioned yet. Maybe it's just because this is my first vehical with a sunroof, but you can open the sunroof/moonroof to the sunroof posistion by pushing in (toward the roof of the car) on the button
#387
#392
Here are some things that I would like to know about my MINI. Any answers out there?
1. Why does the exhaust make that burbling popping sound on overrun. It's way cool, but what makes the sound?
2. What is the technology used by the Limited Slip Diff? Is it a gear type? Clutch? Viscous? It works very smoothly.
3. Various trade publications talk about the MINI's "modular roof system". What is it?
Thanks in advance!
Thanks in advance!
#393
I can't find it either but would really like to! Please give more direction!
"place your hand just forward of either rear wheel neer the rocker panel. Reach up and under the wheel well. You will find a flat 4"X4" secret spot no one know about but you. And tens of thousands of fellow U.S. MINI owners."
#394
Thanks in advance!
Thanks in advance!
Probably referring to the "capped" configuration of the roof. I don't know of too many modern cars that have roofs that extend beyond the glass
#395
Super-Size it!
If you lift the armrest, you can fit a normal-sized (or even McDonalds "super-sized" beverage in the rear cup holder without pinching or spilling. May come in handy for those of you who, like me, thought the cup holder attached to the dashboard column looked goofy and had it removed (and were then forced to use 8oz cups in the front cup holders!)
#396
Originally Posted by ja ME s
Just noticed when i got back tonight - even if the windows are partway down -when you open the doors - the windows "roll" down the half inch they would to open the seal.
if the window is all the way up. Do both of yours do it or just the driver's side?
#398
#399
The rubber "coaster" in the rear cupholder removes for cleaning. (Discovered while vacuuming Car84 last night.) Not too exciting or sexy, but I'll keep trying to find new stuff.
The parcel shelf "rear gate effect" is great for steadying the pups to leash their collars prior to egress. I have a car blanket which I flap over my rear bumper before I put/remove anything (or anyone) from the boot, works great!
#400
Originally Posted by petecrosby
My '03 doesn't do this and I question whether yours should. Mine only does the jog
