Tap wiper stalk down quickly and wipers swipe once slowly, hold wiper stalk down a little longer and the wipers will swipe FAST once! Found this out on the way home today from work.
2. The unlocking the car with the key to the chin thing does work. I LOLed when I did it. I also discovered that my 2 keys work at different distances without using my chin. One key works at over twice the distance of the other one.
Get a new/charge the battery in the 2nd key, then that ones range will increase
Make sure you press and hold the unlock key for at least 5 seconds. I always click twice to open all the doors and then hold it in for 5 to roll down the windows. If that still doesn't work, that function is indeed a dealer controlled option. You have to take in in and ask for the option to have auto-down if you don't already have it. Hope that helps...
-David
None of this worked for me. I guess I'll have to ask the dealer to program it for me. And they will do for me no charge because _no one_ ever mentioned I had programming options during the entire process of ordering/buying the car.
The new key, the one that has never been used in the 17 months I own the car, is the one that worked from twice the distance. Doesn't make sense to me, either.
I think you have to have this set by the dealer, it is programable. If you look in your manual there are several options that you can program to your liking... window opening, door locking, etc. If you want it to change from what you have you need to have the dealer program it.
Your service advisor can program a ton of stuff into your key. The "window/ sunroof remote open" and "door lock window/ sunroof closure" functions are just a few examples.
They give us non-MINI owners the insatiable desire to work more hours, save every penny and read every forum in the hope that maybe one day i'll have a MINI of my own.
FOUND OUT THAT IF THE CAR IS TURNED OFF AND I TURN ON THE RADIO THAT THE BUTTONS ON THE MFSW DO NOT WORK
I have experienced that too and I was sort of bummed about it. However, SOMEtimes (I was baffled by this) they seem to work just fine with the motor off and the radio on. I think it's related to atmospheric pressure somehow.
Until then, happy motoring everyone!
Welcome to the way I spent some of '03 and all of '04. If you end up with a turbo, there's a good chance that I won't want to hear about it!
Hey JCWDriver: I picked up my new MCC yesterday after 6 weeks of surfing NAM. You mentioned "programming the key". Are you saying my personal preferences for programmable options key sensitive? I've discovered key #2 doesn't perform at all and I thought maybe that was because it was not charged up yet. Your comment makes me think that options are key sensitive. Can this be true?
You can have the chime set to go off when you have about 1/8 of a tank of gas. This way when your MINI suddenly dings you scramble to find out why (below 37 degrees, low tire pressure, and now low fuel). And if you are real lucky you will hear all three on a single drive home.
Does this have to be done by the dealer or is there a cheat for it?
