R50/53 Things You Didn't Know About Your MINI
Old 10-21-2006, 07:43 PM
COR BLMY's Avatar
COR BLMY
COR BLMY is offline
I have the "thump thump" as well
Never thought about fuel pressure ... maybe
  #552
Old 10-26-2006, 03:23 AM
rjyoder4's Avatar
rjyoder4
rjyoder4 is offline
Adjustable Washer Jets
I'm relatively new to the MINI neighborhood, but I've not seen this before in a car. When I bought my MINI (02 MC CR), two of the four windshield washer jets sprayed off to each side of the windshield. Upon closer inpection I found that the jets are actually in adjustable sockets, which you can basically aim (this might be handy for those pesky aggressive drivers) (Hmmm . . . maybe not.)
Anyway, later - being very careful not to clog or otherwise mutilate the jets, I was able to use a straight pin to aim the jets where they should go.
Alas, the back washer jet is not adjustable - Now that would really be cool.
Anyone else notice this or have I just lobotomized my washer sys. Still works well (better in fact).
CCY
  #553
Old 10-26-2006, 04:28 AM
petecrosby's Avatar
petecrosby
petecrosby is offline
CCY
The windshield washer jets of most cars are adjustable to some degree, I think.
As for the rear jet, it is adjustable at least on the 2002-2004 models. The jet is turned, using a coin or screwdriver. Rotate it far enough and you can spray other cars with it as you pass them . Later cars have a different type of nozzle and I don't know if it is adjustable or not.
  #554
Old 10-26-2006, 12:27 PM
ImagoX's Avatar
ImagoX
ImagoX is offline
Originally Posted by ururk
There is a little thump---thump---thump from the rear of the MINI, whenever you start up. I've found it is mostly noticeable on a cold morning.
I've been told it may have something to do with the fuel system (like the tank pressurizing, etc...).
I am not making this up...hopefully!
This is just Spridle and Chim-Chim asking for you to turn on the heater. Just toss a ham sandwitch or something back there and they'll shut up. Just for pity's sake, NEVER LET THEM OUT OF THE TRUNK, lest this happen to you:
  #555
Old 10-26-2006, 08:41 PM
Floydfan's Avatar
Floydfan
Floydfan is offline
Wow! I learn something new all the time lol.
  #556
Old 10-26-2006, 09:02 PM
Motor On's Avatar
Motor On
Motor On is offline
Bheind the drivers side cear paneling under the C-Pillar, above th cubbie and foreward some there is a fuel door release handle.
(I think thats a new one)
  #557
Old 10-27-2006, 07:47 AM
Turcicus's Avatar
Turcicus
Turcicus is offline
On my '06 w/o rain sensing wipers, the rear glass wiper wipes every 10 seconds when on by itself, and once every three wipes of the windshield wipers when they're both on (note this 1:3 ratio = constant wiping of the rear wiper when the windshield wipers are on high).
  #558
Old 10-29-2006, 11:00 AM
Cher222's Avatar
Cher222
Cher222 is offline
I need help! I am getting a MCSC. Can anyone tell me if skis and/or a snowboard can fit via the trunk with the back seats down? I am 5'7" and I either have to buy new ski ir snowboard equipement and I am pretty much going to make that decision according to what can fit via the trunk.
thanks,
cherise
  #559
Old 10-29-2006, 11:44 AM
CDMINI's Avatar
CDMINI
CDMINI is offline
What are the cut-outs and foam for, in the rear section adjacent to the floor of the boot area? Air circulation?
  #560
Old 10-29-2006, 12:01 PM
Motor On's Avatar
Motor On
Motor On is offline
Cutouts, Air circulation, Foam noise deaddening, its been awhile since I've had the foam in there, and I've even hidden the holes without issue.
  #561
Old 10-29-2006, 03:29 PM
umberto's Avatar
umberto
umberto is offline
cher222....my snowboard together with my daughter's fits in just fine....won't be long now..........
  #562
Old 10-30-2006, 07:33 AM
Mini2Go's Avatar
Mini2Go
Mini2Go is offline
Coordinator :: Pitt Stop MINI
thanks,
cherise
Sorry I don't know the exact answer to your question, but here's an option for you to consider:
MINI FINI Ski/Snowboard Carrier
The system is a little pricey, but expandable/versatile and pretty nice overall.
Oh, lest you get someone confused, the MINI doesn't have a trunk - it has a boot!
  #563
Old 10-30-2006, 10:25 AM
FL_blue_MINI's Avatar
FL_blue_MINI
FL_blue_MINI is offline
Originally Posted by DrkSlvrS
Another thing you might not know about your MINI - it speeds up in the corners!
I've done scientific studies - take a freeway on ramp marked at 35MPH and as you exit the turn check your speedo ... and your already crusing at 65.
I have done this, it really is true!!!!
  #564
Old 10-31-2006, 02:28 PM
CIGARGUY's Avatar
CIGARGUY
CIGARGUY is offline
I didn't know that this would be the only car that I'm still in love with two years later. I also didn't know that I could become attached to any car as much as I am this one. You can't pry my hands off of it!
  #565
Old 10-31-2006, 02:30 PM
myzamboni's Avatar
myzamboni
myzamboni is offline
Originally Posted by Turcicus
The rear glass wiper wipes every 10 seconds when on by itself, and once every three wipes of the windshield wipers when they're both on (note this 1:3 ratio = constant wiping of the rear wiper when the windshield wipers are on high).
Not on an '04.
  #566
Old 10-31-2006, 04:51 PM
Rawhyde's Avatar
Rawhyde
Rawhyde is offline
Originally Posted by myzamboni
Not on an '04.
Doesn't work on an 05 with rain sensing wipers. Did the car it worked on have rain sensing wipers?
Rawhyde
  #567
Old 11-03-2006, 03:42 PM
JJ Blue's Avatar
JJ Blue
JJ Blue is offline
If you look in the lower drivers side windshield you will notice that your VIN number is displayed.
  #568
Old 11-03-2006, 03:48 PM
qweewq12's Avatar
qweewq12
qweewq12 is offline
ahhh... WHAT? Can someone translate that for me pls...
  #569
Old 11-03-2006, 05:49 PM
RR XING
RR XING is offline
I found this out after 2 months. On the MFSW stero control, if you press the up arrow you advance tracks on the CD (knew that), but if you press and hold the up arrow, you can fast forward. Holding the down arrow is reverse.
  #570
Old 11-03-2006, 11:39 PM
rkw's Avatar
rkw
rkw is offline
It has a similar function for the radio as well. If you press up or down, it goes to the next or previous preset. But if you press and hold, it will scan the radio frequency for the next station.
  #571
Old 11-04-2006, 08:53 AM
erickvonzipper's Avatar
erickvonzipper
erickvonzipper is offline
Thank you. That is good to know.
  #572
Old 11-06-2006, 06:40 AM
Louispup's Avatar
Louispup
Louispup is offline
If you (God forbid) don't lock your MINI; when you return if you go to "unlock" your car with the keyfob (which you don't realize is already unlocked), the ceiling light comes on at any rate.
  #573
Old 11-06-2006, 02:05 PM
Turcicus's Avatar
Turcicus
Turcicus is offline
Rawhyde
Ah, thank you - I didn't qualify it by saying it worked on a car ('06) w/o rain sensing wipers. Original post edited.
  #574
Old 11-07-2006, 09:37 PM
PrplPplEtr's Avatar
PrplPplEtr
PrplPplEtr is offline
wow, can't wait to verify this as that was one of my "nags" about the mfsw.
presets are great, but having the scan on the wheel too rocks.
i luv this thread!
  #575
Old 11-08-2006, 08:57 PM
cmyk's Avatar
cmyk
cmyk is offline
thanks,
cherise
I don't know what space is sacrificed with the convertible, but a 160 snowboard JUST fits in my MCS. It goes all the way from the very back to just about where the gearshift rests if it's in 4th gear.
I'd say you could fit 2 (in boardbags of course!) up the middle, but only in an emergency snowboard session
Keep in mind that was how a 160 fit. Usually skis are much longer!
Quick Reply: R50/53 Things You Didn't Know About Your MINI
