R50/53 Things You Didn't Know About Your MINI
Old 01-26-2007, 04:21 AM
rc'S's Avatar
rc'S
rc'S is offline
2006 MCsC
Read about the key fob to the chin/cheek think and agreed with works just because it is higher up than your waste. Raised it as high as i could, about 7+ft and it would not open the doors. Tried it a couple of times. Standing in the exact same spot, put it to my cheek, face that is, pushed the button, and light show time! It did work.
Also, no beep when the key is by the switch in any maner. Turned the key on to acc and sat there a moment. The speed-0-meter flashed 8,700 to oil change. Didn't read that here.
  #727
Old 01-26-2007, 07:56 AM
ScottRiqui's Avatar
ScottRiqui
ScottRiqui is offline
That's interesting - we have two 2006 MCSCs, and with either car, if I hold the black plastic part of the key up to the keyhole (without inserting the key), I get the "door open" chimes (only works when the door is open, obviously). Also, it only works when the keyfob is within about 3/4" of the keyhole.
  #728
Old 01-26-2007, 07:59 AM
rc'S's Avatar
rc'S
rc'S is offline
OK, I'll try it again after I first get in.
  #729
Old 01-28-2007, 12:25 PM
ScottinBend's Avatar
ScottinBend
ScottinBend is offline
Did you know that the side bolsters on the sport seats are not the same size. The inside ones are larger than the ones next to the door.
  #730
Old 02-08-2007, 09:24 AM
Tandaina's Avatar
Tandaina
Tandaina is offline
Something I found out yesterday - during these freezing nights in Los Angeles - If the outside temperature reaches 37 degrees, the onboard computer beeps at you, and flashes the temperature, regardless of what you have on the computer (I tend to keep my speed showing there)
Can this "feature" be turned OFF? I pick up my Mini in less than a week and do NOT want the thing beeping at me when its under 37 degrees. Where I live that's almost 6 months of the year! I KNOW its <37 car, its actually -2 (F) right now so shush and DRIVE!
  #731
Old 02-08-2007, 11:16 AM
yumhaggis's Avatar
yumhaggis
yumhaggis is offline
It only does it on start up, & it's only a reminder that there might be ice on the road. It's not on more then 30 sec. or so.
  #732
Old 02-08-2007, 11:48 AM
petecrosby's Avatar
petecrosby
petecrosby is offline
Yep, it only chimes for a few seconds. It also chimes if the temperature drops to 37F while the car is on.
  #733
Old 02-08-2007, 11:58 AM
HotRodPilot's Avatar
HotRodPilot
HotRodPilot is offline
Originally Posted by MiniBetterThanBeer
Also, the exhaust tips point a little to the left whenever it's really cold out.
I noticed this too a couple of weeks ago, and I've had the car for two cold seasons now. I'm glad it's not just mine / not a "defect"
Old 02-08-2007, 01:08 PM
yumhaggis's Avatar
yumhaggis
Tru Dat my bad your right it is after all a heads up for ice on the road.
  #735
Old 02-08-2007, 01:48 PM
Tandaina's Avatar
Tandaina
Tandaina is offline
Hehe, I just assume that November through April there is likely to be ice out. Well that and the frost on windows in the morning. So long as its not an "error" beep and it goes off quickly I suppose I can stand it.
  #736
Old 02-19-2007, 07:23 PM
zagadka's Avatar
zagadka
zagadka is offline
i didn't know that people were as nuts as me with giving inanimate objects personality. i'm not alone!
i've learned lots of stuff in here, thanks guys!
  #737
Old 02-20-2007, 05:25 AM
erickvonzipper's Avatar
erickvonzipper
erickvonzipper is offline
Waddaya think, that no one else named their teddy bears, either??
Zip
  #738
Old 02-20-2007, 11:59 AM
everytimeidie027's Avatar
everytimeidie027
everytimeidie027 is offline
Zip
haha good point
  #739
Old 02-20-2007, 06:10 PM
zagadka's Avatar
zagadka
zagadka is offline
well, i never had a teddy bear. but, i named my baby blanket (which i still have and still sleep with, thank you!).. Dee Dee.
  #740
Old 02-20-2007, 07:18 PM
minimarks's Avatar
minimarks
minimarks is offline
Originally Posted by shankrabbit
yeah... you don't have one of those?
like this:
I didn't know Stephen King had a mini...
  #741
Old 02-22-2007, 01:37 AM
blackeyedsuzie's Avatar
blackeyedsuzie
blackeyedsuzie is offline
Originally Posted by cdn_miniac
Ehh...I can turn my lights on manually.
Plus...I'm the type of guy who likes to warm up his car while it sits in the driveway…and without DRL…at least my MINI wouldn’t look like an 'easy ******’
-Nick
Did you know that the owners manual specifically says not to let your car "warm up" but to instead drive right off after starting. :
  #742
Old 02-22-2007, 06:40 AM
erickvonzipper
Yep, today's cars don't need to be warmed up more than about 30 seconds. You're supposed to drive right off, as she said. Just take it easy until the needle comes up to half way.
Zip
  #743
Old 02-22-2007, 07:01 AM
eager2own's Avatar
eager2own
eager2own is offline
That's what I do -- the speedometer needle, right?
  #744
Old 02-22-2007, 08:25 AM
fred3's Avatar
fred3
fred3 is offline
Errrr...no....
Zip
they mean you don't have to wait any time at all...you don't even have to wait your mentioned 30 seconds. It just isn't necessary or desirable (according to the manual which we all *ahem* read before we drove) at all.
  #745
Old 02-22-2007, 09:15 AM
petecrosby's Avatar
petecrosby
There are three things which generally determined the need to let a car warm
up before driving it:
1. Allow the car to run and idle smoothly by getting it off the choke.
2. Allow the oil to warm up to provide proper lubrication.
3. Allow the coolant to warm up so the heater would work in the wintertime.
But today:
1. With modern ECUs employing closed feedback systems and fuel injection
controls this is no longer an issue.
2. Modern multi-viscosity oils and synthetic oils eliminate this issue for the
most part (except in really cold climates).
3. This problem has not been solved but can be somewhat ameliorated
through the use of seat heaters.
Now, I suspect there are really two reasons why auto manufacturers
suggest today that you not allow a car to warm up for a significant period
of time before driving it:
1. Until the engine reaches full operating temperature, the fuel supply is
increased, causing the engine to run rich which can lead to spark plug
fowling and reduced catalytic converter life. Immediately driving the car
allows the engine to reach full operating temperature more quickly and get
if off the choke cycle.
2. They are encouraged (by the government) to suggest you not warm up
the car due to the increased emissions generated by the over-rich
condition during the choke cycle (which is really fuel enrichment rather
than the limitation of air, which is where the name comes from).
A properly running car should quickly burn off any carbon and clear out the
cat without causing any problems. Allowing the car to warm up in the
wintertime won't really hurt the car but will decrease your fuel economy and
add somewhat to our air pollution problems.
  #746
Old 02-22-2007, 11:03 AM
erickvonzipper
Hmm, not enough info on my part. Here:
When I stated thirty seconds, I was referring to the time it takes, after I start the car, to put on my seatbelt, driving gloves, turn on the radio, and turn off the DSC. To me, 'warming up' means the bad ol' days of starting the car up and then going back in the house to get my stuff together for the day. Until my '73 Mach 1 is sufficiently warmed up, especially in winter here in the metro NYC area, it doesn't like to be prodded more than just a little bit. Then, as it acculumates a few miles, it reacts better. Such was life with the old carbureted hulks we used to (and still occasionally do) drive. After only seconds with a modern computer controlled car such as our MINIs, we can motor away with no driveability problems. I just take it easy until the temp needle climbs up into its proper position, usually in just a few minutes of driving.
Zip
  #747
Old 02-23-2007, 09:36 AM
Gromit801's Avatar
Gromit801
Gromit801 is offline
I hadn't noticed before yesterday, but when driving along with the windshield wipers in normal speed mode (no automatic rain sensor), they will revert to an intermittent speed when I come to a stop! Way cool.
  #748
Old 02-23-2007, 09:55 AM
Rennie's Avatar
Rennie
Rennie is offline
Yes, they are speed sensitive wipers. And if you have them on intermittent and you come to a stop, they stop (I believe). This is good, but I do wish we could control the intermittent speed instead of having just one speed.
  #749
Old 02-23-2007, 11:31 AM
Gromit801's Avatar
Gromit801
Agree with you there. I mean even an old Hyundai I once had in the 80's could do that!
  #750
Old 02-23-2007, 09:09 PM
aorr's Avatar
aorr
aorr is offline
I just spent the last 9 hours and 37 minutes reading this thread.
Ah, well, okay, I broke it up into two days of reading, but I kept track of my time. :D
All 750 posts (including my own!) And after reading it all, I have nothing more to add. :( All I can say is that there are a LOT of repeats in here. Please, before you ask how to do something, read the thread! You'll get an answer about a dozen times.
Great thread though, some wonderful ideas. I complied a list of the best ideas the thread has, so if you want a short-and-sweet version, send a PM to me.
Happy motoring!
-Andy
EDIT!
PM your email address to me and I'll email it to you! It's too long for a single PM! :-)
Quick Reply: R50/53 Things You Didn't Know About Your MINI
