R50/53 Things You Didn't Know About Your MINI
#1876
I bought a CR2032 at a local mall watch kiosk for $6.25. The girl tried to just give it to me because her register was broken and it would be a few minutes until she could ring me up. I didn't have the right breakdown of cash so I waited and gawked at men's watches for 10 minutes. I have a June build 2002 MCS. The key fob does have a snap locking case and opened with a small screw driver (do use caution) inserting the straight edge under the key ring area. The orginal CR2032 battery was held by 3 small plastic tabs that the battery easily snapped out from under. The new battery snapped in, the plastic cover snapped on, and the keyfob works perfectly and much farther away than before. The life span of the original battery was 104,000+ miles and 8-1/2 years. It's the only key/fob I have so it is well used but not heavily worn. Compared to a Ford model fob if the same era I'd say the MINI fob is slightly more heavy-duty.
Of course, that's just me and my MCS. I'm sure key fobs of various years and generations are slightly different since that is likely a third-party manufacturer's component.
#1877
You can have the chime set to go off when you have about 1/8 of a tank of gas. This way when your MINI suddenly dings you scramble to find out why (below 37 degrees, low tire pressure, and now low fuel). And if you are real lucky you will hear all three on a single drive home.
#1880
You folks in SC aren't supposed to see any ice unless it's in a glass of lemonade! What's going on with the weather?!! Geez!!
#1881
#1882
#1883
#1884
I just obtained a 2004 Cooper, which is in near perfect condition, except for 1 curious thing: Both the front and rear Mini emblem have lost their black fill. The whole thing is now silver. I suspect a suspect clearer of some sort was used over time. But, does anyone know where I can get replacement badges and how I can get the old ones off & new ones on?
#1885
Outmotoring sells replacements. It appears that the front emblem has posts and tape, while the rear emblem is just held on with double-sided tape.
#1886
When you park and leave your MINI in public parking it quietly invites larger vehicles to share the unused portion of it's parking space. What a polite car.
BTW: Just because I don't take up the whole parking space doesn't mean you can have what I haven't used. F'n @$$holes. People need to learn how to park
#1887
#1888
I replaced my rear emblem in December of 2008, it also had holes for pins on the back of the emblem and double-sided tape. I bought it while in Florida from the MINI dealership in Orlando for $40.02 (tax included). Outmotoring.com is selling them for $35. Mine wasn't really fading but the black was cracking up underneath, similar to the steering wheel emblem.
It's funny that you mentioned this - just yesterday, I noticed that the black fill was missing from the emblem on the front of my 2006. I've never used anything on it more aggressive than car wash soap, so it may just be a result of living outside for four years.
#1889
That said, most of them were at least inaccurate in a predictable way, so when it got to 1/2 or 1/4 tank, I could guestimate how much gas it'd take within half a gallon.
C ya,
Dutch
#1890
in my 09 i just recently discovered when changing from Radio to CD to Aux, instead of hitting the "audio" button, then using the dial to move to one of the three options, say from Radio to CD, instead you can double tap the audio button and it will rotate through which of the three options you'd like depending on how many times you keep tapping the button. Pretty useless but after having my car for a year and a half, its surprising that i just found that out.
#1891
I've gotten really good at taking up the whole parking space....
I also tend to seek out spots that have protection on one side or both. Or, if nothing else works, I park next to another premium vehicle, on the assumption that they, too, care about their car, and will be careful not to door-ding me--even if it's only out of fear of getting my paint on their car....
C ya,
Dutch
C ya,
Dutch
#1892
When I can, I park at the far right-hand end of a parking row, as close to the right-hand side of the space as I can. That way, nothing is likely to hit my car on the right side, and if the car that's parked on my left doesn't have a passenger in it, there's nothing to worry about from that side either.
4-1/2 years and 75k miles, and I've managed to only accumulate two tiny parking lot dings.
#1893
C ya,
Dutch
C ya,
Dutch
#1894
#1895
#1896
#1898
Here is what I assume:
1. People are Lazy - stay away from the spots closest to the door/entrance/elevator/etc as they will try to park as close as possible and will attempt to squeeze the car into any open space near the door.
2. People are in a hurry - apply the same thought to number one and that is when I see people whipping into spots hitting other cars, etc.
3. Avoid anyplace near a shopping cart park spot, or anywhere near down hill of shopping carts.
4. Avoid mini vans and other large vehicles that can hold careless children, if you must, pick the one with the sliding door.
5. Always park on the passenger side - 50/50 chance no one is getting in that side.
6. Park the farthest space and highest level in a garage from the exit - Most people will never park near you as rule 1 applies
7. Park next to an expensive car - Yes, money sometimes does buy respect for others property sometimes.
8. Park next to a same make/model of your car if it is a "car with a cult following"
9. Don't back in - you are asking for your mirror to get smashed by the rear door of another.
10. NEVER take two spaces - No your car is never more special than the others in the lot. It screams arrogance and you are asking for a punk to do something to your car
Yes, people hate being my passenger!
#1899
Searched and couldn't find this one. I accidentally hit my flash the high beam mode on the turn signal. This was after I shut of the car and removed the key.
The low beams (xenon) came on and so did the driving corner lights and stayed on.
I thought I somehow turned them on, nope. Cycled through the off, parking, on and then back to off and it shut everything off.
Pulled the flash to high beam again, lights came on, stayed on.
Got out of the car, locked it with the remote and after about 1.5 minutes or so everything went off.
I can only assume this is a coming home light function so you can see the house/walk/drive way when coming home and exiting the car.
It's probably in the manual right?
#1900
Literally all of those parking rules went through my mind as I was circling for a good spot this morning in my school lot. I ended up next to a snow mound because I figured, that's one less side of the car that is at risk, and its the farthest lot from the building, the spaces are wider, and my mini fits in with plenty of room. I folded the mirrors up though juuuust in case
And the lighting feature mentioned above i believe is the "follow me home" thing, but yes, its in the manual.
