R50/53 Things You Didn't Know About Your MINI
#2126
Schrodinger's Engine Bay
If you drop a 10mm socket in the engine bay it is both there and not there until you either pull the entire bay apart or you find the 10mm in your driveway.
https://en.wikipedia.org/wiki/Schr%C3%B6dinger%27s_cat
I am sorry to disapoint everyone who opens this and is looking for a list of things they didn't know.
I got an Idea as I was reading the manual to my dad's new HUMMER. What are some things that most people do not know about their MINI? Intersting little bits of information, odd facts, interesting tricks....LIST EVERYTHING YOU KNOW THAT YOU THINK SOMEONE ELSE MIGHT NOT!!!!
#2129
#2130
I'll share my embarrassment - I blew compressed air through the seam of the sunroof and managed to blow off the collection tube that drains water out of the sunroof channel. I discovered this as I was going through a car wash and noticed water dripping through the headliner. I don't know if they've improved the fitment of the drainage tube but it isn't an unknown or isolated event, I'm told!
#2131
#2132
#2133
#2134
#2135
No worries, easy to miss as there are lots of little/obscure indicators accompanying each post and poster on the forum. Wouldn't it be a hoot if he did respond.
#2137
I got mine (silver trim) from AllMag.com (FL). I was hoping for Anthracite trim to match my interior. It was mentioned that it was never produced in Anthracite.
Wrong - I came across one at a salvage yard but someone had butchered it to get to the EBrake handle.
#2138
I have seen this on the front of some cars. Must be a cost savings deal since not many have it. Also would increase the price of a front windshield replacement.
#2139
Not sure if this was covered but if you turn the car off with the lights on, turning off the headlamp switch will not turn off the lights. You have to cycle the lamp switch again or turn the ignition back on to turn off the headlights. Not sure how many models this applies to but mine is a 2002 S with HID lights.
#2140
A few I just learned while screwing around in NCSExpert (for R53):
-after the ignition is off, if you pull the brights twice it will go into 'follow me home' mode, which will leave the headlights on for X amount of time (which can be set)
-there is also a setting to roll down the driver's side window when you press unlock twice. It rolls down when you open the door! (super cool)
-holding the unlock button will roll your windows down and open the sunroof, but this can also be modified to only roll down the windows. Super useful in FL. I'll be looking further into the programming for this, as I think I can make it roll down both windows and just pop up the sunroof (unresearched, so we'll see)
Bonus: -auto up can be enabled in NCSExpert, although it depends on build date as to whether it will work for both driver and passenger side
#2141
So Bizzare
I had just upgraded my pre-facelift Xenons with OEM facelift Xenon projector headlights. There was a problem with the driver side low-beam not working. While I had the ignition turned off, all the windows completely up and the sunroof closed I lifted the hood to check/reseat the headlight wiring plugs. I unplugged and re-plugged in each of the main headlight connectors. Closed the hood and to my surprise = all of the windows were down and the sunroof completely retracted.
I thought I was just being forgetful....or crazy
However; this happened each time I unplugged/plugged in the headlight wires.
That's a new one for me
#2142
There have been a few posts where the auto roll down and sunroof opening happened while parked and the car getting soaked by rain causing electrical issues and BCM damage. I’ve had it happen once, but luckily no rain or theft. Not sure if it was other keys pressing against remote in my pocket or just a random MINI electrical glitch, but that’s something I’d like to code out in the future.
#2143
Something else I do know and don't know about my Mini....
During the colder months (Nov - Feb), my car alarm will go off and reset several times until either the engine cools down or the wind ceases to change direction.
It's not so much as annoying to me as it is, perhaps to my neighbors.
Although I do have INPA, NCSExpert and NCSDummy installed on one of my laptops (when the car was tuned), but I've never and don't know how to use it.
I wonder if there is a sensitivity setting that can be adjusted for the alarm/immobilizer?
#2144
#2146
#2147
That's kind of you to offer - but man, I wouldn't wish braving those cold temps on my worst enemy...just to have a look for curiosity sake.
However if you do happen to spot something (alarm sensitivity), through any of the apps; I would be greatful if you could share some insight.
Thanks!
That's not a bad suggestion.
My Mini has lived most of it's life in sunny FL and the SW. The alarm never went off during those years and only if the car was bumped of jarred when locked and armed.
It was only in the last few years after having moved 500mi N that the siren would go off when temps fell below 50°. Within those first 3years, during the colder months, that the alarm went off constantly to the point where the audible siren finally stopped working and only the lights would flash. I finally pulled the alarm out and took it apart. I discovered that the small wire connected/soldered from the board to the siren had detached. I soldered it back in place and all was good again. Well, that is; for me and my Mini...Probably not so much for my neighbors....
I digress.
To your suggestion: I think I'll try and add some sort of thermo insulator around the immobilizer/tilt sensors to see if that might actually work.
Thanks!
#2149
8 deg F when I got up this morning. Never got about 15 deg. And there was a wind. I stayed in today.
thermo insulator - Won’t hurt to try.
However, I was thinking more along the lines of something inside the sensor is broken and the cold is causing 2 things (plastic vs metal, maybe) to contract at different rates causing it to think it is feeling a vibration from the car. Or something along those lines. I would think something like insulation will just slow the process of cooling off, but given enough time, it will be at the outside temp. But maybe getting there more slowly will work for you? Don’t know.
#2150
Ha. It was in the teens when I woke up this morning. My condo has a bunch of single-pane windows that don’t seal well, and this heat pump is struggling.
No worries about the cold though. I always read and save the files I plan on modifying, both to verify that I have all the latest changes I’ve made and to make sure I can communicate with the car. No need to sit out in the cold to look through them.
I didn’t see anything in my BC1 file that indicated sensitivity. It could still be there somewhere since my version of NCSDummy is old though.
