R50/53 Warranty Voided?
Warranty Voided?
I've read a number of posts for people suggesting that JCW parts are the way to go for mods to avoid having your MINI warranty voided (even with M-M protection). My question is how many people have had warranty problems? And if you can discuss it, what was the problem and what caused it? Even though the JCW stuff looks trick I'm still trying to justify the number of beer credits involved. Thanks for your help.
Originally Posted by HEMI-MINI
Check out whiteroof radio...they covered this very topic!
Check out the sponsors. Some have their own forums to ask about their warranty policy. If not, you can usually find them here on NAM.
I'm not saying don't go the route of JCW. It's a good product. If I could have tacked on an extra $6,000, I would have. But I couldn't.
hehehe "beer credits involved"
anyway -
Here is the thing. I don't know how new your car is, but if you're anything like me, you're going to easily blow through that 36k in a year or two. I'm at my first year of ownership and I'm nearing 25k.
I'd say look around for aftermarket mods that offer warranties on their parts. That way if you were to get a SC pully, and your supercharger blows, it's covered under the aftermarket warranty, and if your radio or steering goes, it's still covered under the M-M. (though some MINI dealerships may claim that your after market pulley cause an inaudible frequency signal to be transmitted to the far of planet of Chriosos which caused aliens to come and dismantle your steering bits... but I digress)
Just play it smart and play to your pocket book. If you can handle going stock for a year or two and then modding after your warranty... I'd say do that. If you need the power now, but don't want to chance warranty issues then go with the craptastic JCW.
Just a thought...
anyway -
Just a thought...
Originally Posted by SB
Woofcast 39 to be exact. Just because you throw on an aftermarket pulley doesn't mean if your radio dies it will not be covered. .
Originally Posted by not-so-rednwhitecooper
dealer wont touch my car.
better for me, they never fix anything the first time or they break something while they fix another.
your better off fixing it yourself.
Originally Posted by motor on
Don't be stupid...
Woofcast 39 to be exact.[...]
It was an interesting show. But, unfortunately, the guys didn't fully cover some of the most important questions. Here's an example: you put a 15% pulley and cold air intake on your car, and later the supercharger or a piston fails. Suppose the dealer claims, reasonably, that the mods caused the failure. The factory warranty on my '05 MCS would be void for that supercharger or piston in that case. MINI might be wrong about the cause of the failure (the factory part might have been defective) or they might be right.
The default situation is that MINI is the recognized, acknowledged authority on whether a mod has caused a factory part to fail. So, who will pay for the repair if MINI says that your pulley and CAI caused a factory part to fail? You will, unless the pulley and CAI came with a vendor warranty that will cover repair/replacement of the factory part. That's why a vendor warranty is so important.
I suggest to anyone who is considering a performance mod that they should consider the possible impacts of the mod to their factory parts, and at least check out vendors whose warranty will cover those impacts.
If you go aftermarket, buy from a Vendor who fully warranties their work and be fully prepared to potentially lose your manufacturers warranty. It's as simple as that.
Search under M-M on this site if you need more info...............
Here's a link to a long discussion on this topic.
https://www.northamericanmotoring.co...hlight=lawsuit
More pulley questions
Long, long list .... mostly minor stuff, some major
No squeak or rattle stuff, too many to mention list before the thread ran out of steam Since then, there have been several new engines (MDSbrain) ... blown gaskets, etc.
3 Steering wheel
2 Engine
1 Shift ****
1 Cat
5 Steering column
1 Windshield molding
1 Dash down tubes
1 boot glass repair
1 Ash Tray
1 ECU emissions reflash
1 center switch assembly
1 "plastic debris causght inside the blower motor fan area"
1 "Crash collapsing mechanism in steering column"
2 A/C blower
4 Windshield
1 Climate control Module
3 Belt
1 Clutch
1 Flywheel
1 Belt tensioner
1 Slave cylinder failure.
1 HK buzz.
1 Sirius antenna failure
4 Passenger door mechanism
1 Drivers Door release cable
1 Trim piece on passenger side wiper departed vehicle
1 Keyless remote on 1 key dead
4 transmission replaced
1 passenger's seat rails replaced
1 driver's seat rails replaced
1 center instrument panel replaced
1 airbag light due to seat airbag wiring
2 sunroof rattle
3 Drivers door side mechanism
1 seatbelt tensioner
1 Airbag Light #2 had wires running to seats
1 airbag inside passenger seat
1 sunroof cassette.
2 Cooling fan
1 Windows and Sunroof opening on thier own, BCM replaced.
1 rear pads and rotors
1 Wires to parking light
2 drivers side door mechanism
1 windows would squeak or not open with the remote
1 alarm wouldnt set
1 underglow kept falling off
2 batteries
1 ems reader wouldnt read the key
1 Brake Rotors/Pads
1 transmission problems
1 new tire and rim
1 glovebox
1 brake computer
1 outside door handles
1 Bonnet vents
2 Boot latch and striker
2 O2 sensor
2 Coolant expansion tank
1 Seat fabric
2 power steering fans
Originally Posted by chows4us
Check here https://www.northamericanmotoring.co...light=warranty
3 Steering wheel
2 Engine
1 Shift ****
1 Cat
5 Steering column
1 Dash down tubes
1 boot glass repair
1 Ash Tray
2 A/C blower
4 Windshield
3 Belt
1 Clutch
1 Flywheel
1 Belt tensioner
1 HK buzz.
2 sunroof rattle
1 sunroof cassette.
2 Cooling fan
1 alarm wouldnt set
2 batteries
1 Brake Rotors/Pads
1 new tire and rim
1 glovebox
1 brake computer
1 Bonnet vents
2 O2 sensor
1 Seat fabric
3 Steering wheel
2 Engine
1 Shift ****
1 Cat
5 Steering column
1 Dash down tubes
1 boot glass repair
1 Ash Tray
2 A/C blower
4 Windshield
3 Belt
1 Clutch
1 Flywheel
1 Belt tensioner
1 HK buzz.
2 sunroof rattle
1 sunroof cassette.
2 Cooling fan
1 alarm wouldnt set
2 batteries
1 Brake Rotors/Pads
1 new tire and rim
1 glovebox
1 brake computer
1 Bonnet vents
2 O2 sensor
1 Seat fabric
Mine has a similar list though yours is more extensive...
Originally Posted by rameeti
On my yet to be delivered '06 MCSCa, I am wanting to do a pulley asap but I also do not want to take any chance of warranty issues. Is the JCW pulley the only warrantied pulley? Is the JCW pulley of a lower quality than the other 15% 'ers? Is there any quality difference among the different 15% pulleys? Can any qualified shop install the JCW pulley and then not affect my warranty? Is the only source for the JCW pulley the dealer?
The JCW kit used to be dealer installed but I believe it's now factory installed. It's around $6000 and (sadly for me and you) it's not available on automatic transmission cars.
I have a 17% Alta pulley on my 2005 MCS auto and I love it. I don't think there's a huge difference between the different pulley manufacturers, but I was already getting an Alta intake so it made sense for me to get the pulley from the same vendor.
Hope this helps -
/gary
At Bill Jacobs Mini, my MA told me that a guy had a supercharger pulley (didnt disclose what %) but he had continuos trouble with the car and MINI decided to buy back his car (knowing he had an aftermarket pulley). I think that is a prety nice gesture. and it turns out that the dealer took off the pulley and replaced it with a stock unit, and it ran fine. My guess is he had maybe a 19% with no supporting mods. but still!
One note of caution about the vendor warranties. If you put a pully on and your supercharger and a piston go bang as someone hypothosized, the vendor might warrant the pulley and (maybe)the supercharger, but my guess is that they won't pay for the piston.....I could be wrong, but make sure you read the fine print.
To make the point clearer, probably you will want to put on the pulley and cover yourself with a combination of the two kinds of warranties so that in a case where the factory warranty doesn't apply the other one will.
The details of the MINI factory warranty will be in one of the manuals that MINI will give you with the car. Knowing what I know now, I would have asked my sales rep for a copy of the exact warranty before my car arrived and any aftermarket parts were installed.
You can get the details of any vendor's pulley warranty by contacting the vendor (usually just by checking the vendor's web site).
Emnotek
09-29-2015 07:37 AM
