R50/53 The Official MC40 Owners Club
Old 05-06-2019, 12:23 PM
mikeschu's Avatar
mikeschu
mikeschu is offline
Do you still have the hood decals? If so I will buy them. Please call me at 484-363-7159.
Thanks,
Mike
  #677
Old 05-06-2019, 02:19 PM
cooper48's Avatar
cooper48
cooper48 is offline
#mikeschu -- sorry, the decals were snapped up right away. See the post above re: Firestorm Graphix -- I believe I paid $57 shipped via their online site.
TWLKR53 (06-06-2019)
  #678
Old 05-07-2019, 10:53 AM
cooper48's Avatar
cooper48
cooper48 is offline
Here is another source (England) for the GB badge on the boot. Note that it is correct for the MC40. https://bullmotifminispares.com/4425/gb_badge_dam100690
The badge is screen-printed black on an aluminum plate. It shouldn't be that difficult to replicate for a graphic artist with a desktop publishing program.
  #679
Old 05-07-2019, 02:02 PM
audihere's Avatar
audihere
audihere is offline
Is that how small the MC40 "GB" emblem is? 58mm x 80mm
Seems larger in photos.
  #680
Old 05-07-2019, 02:42 PM
cooper48's Avatar
cooper48
cooper48 is offline
Measuring my MC40, the "B" is 85mm tall and the total width installed from the left side of the "G" to the right side of the "B" is 123mm.
  #681
Old 05-07-2019, 02:46 PM
audihere's Avatar
audihere
audihere is offline
Then the link sounds like it's for a smaller version. I ordered one anyways.
Maybe the Paul Smith Limited edition?
  #682
Old 05-25-2019, 04:30 PM
cooper48's Avatar
cooper48
cooper48 is offline
Can you dig it?
I've never had a personalized license plate before so I said to myself, "Self, if you can get a certain plate go ahead and spend the $150 annually even though it's a ridiculous price for a plate. So I log on to the state site and lo and behold: poorer but happy!
Brenden (05-25-2019)
  #683
Old 05-26-2019, 12:21 AM
audihere's Avatar
audihere
audihere is offline
Nice plate! Wow, $150 annually seems really high compared to CA.
  #684
Old 12-07-2019, 08:34 AM
cooper48's Avatar
cooper48
cooper48 is offline
MC40 owners: I recently replaced the oil pan plug on my MC40 with the proper sensor plug but my oil temp gauge is still not working. I haven't discounted that the gauge may not be functional since it wasn't working when I bought the car (but it did not have the correct oil pan plug at that time). In an attempt to get it working, I found a loose blue wire (no end connector) hanging near the power steering pump and made the assumption that it was the oil gauge sensor wire. I confirmed it was the same color blue by looking at the connection on the back of the oil temp gauge. I added a connector and plugged it into the oil drain plug but the gauge is still not working. Do any of you having a functioning oil temp gauge and, if so, is that wire blue? Also, does anyone have an idea of how a single stranded wire transfers the temp to the gauge itself?
  #685
Old 12-08-2019, 06:12 AM
Cincy_jro's Avatar
Cincy_jro
Cincy_jro is offline
I have replaced the connector on mine previously and it was a stranded wire not solid single core. A solid core would still work but is more susceptible to breaking. Maybe re run the wire?
  #686
Old 12-08-2019, 07:27 AM
cooper48's Avatar
cooper48
cooper48 is offline
Cincy_jro, do you recall if your connection wire was blue?
  #687
Old 12-09-2019, 07:21 AM
ALLMAGAutoParts's Avatar
ALLMAGAutoParts
ALLMAGAutoParts is offline
Where did you find the oil pan temperature sensor? The original ones manufactured by VDO have been gone for quite some time.
We've dismantled a few MINI's with the factory gauge set up and I believe the wire at the pan is blue.
Cincy_jro (12-09-2019)
  #688
Old 12-09-2019, 07:31 AM
Cincy_jro's Avatar
Cincy_jro
Yes. I believe it is blue also and it has a black tubing on it for heat protection since near the exhaust. It should have been a multi-strand wire and not solid core though. I have rarely seen solid core used in automotive (at least not since the 70's) because solid core is easily fatigued and will break with movement. If you can do it I would pull a new wire from the gauge to the sensor and solder the female spade connector to the wire so it doesn't corrode.
  #689
Old 12-09-2019, 04:41 PM
ACGOG's Avatar
ACGOG
ACGOG is offline
Not sure if this is a dumb question, even feasible or already answered in this thread (looked through most of it) but I'm assuming there's no way to find out what number my MC40 is? From what I've read here it doesn't sound like the VIN is connected in any way. My dad did register on the fan site back in the day but I don't think it's still active. Since I'm changing the appearance of the car and working on it bit by bit, the only thing really connecting it to an MC40 anymore is the floor mats and the shift ****.
  #690
Old 12-09-2019, 06:08 PM
cooper48's Avatar
cooper48
cooper48 is offline
VDO gauge sensor
Here you go:
  #691
Old 12-09-2019, 06:10 PM
cooper48's Avatar
cooper48
cooper48 is offline
You're correct, nothing in the VIN will tell you. That's because the MC40 was a dealer-added package to a slick-top, Chili Red Cooper S. I have my original window sticker and it was an $8,000 option.
  #692
Old 12-09-2019, 06:13 PM
cooper48's Avatar
cooper48
cooper48 is offline
The blue wire I found near the power steering pump is a blue stranded wire (same color that exits the gauge). I attached a female connector and hooked it to the new oil drain plug sensor but I'm only receiving a minimal reading on the oil temp gauge. Next step is to remove the gauge and find an electronics repair shop to determine if I'm just spinning my wheels. I'm hoping that it can be repaired so that I can keep my MC40 as stock as possible. Thanks for the reply.
  #693
Old 12-10-2019, 07:13 AM
ALLMAGAutoParts
Here you go:
Thank you for sending this over! I've looked at this one. It is quite a bit shorter than what was originally used with the VDO gauge set from MINI, also has less threads so it doesn't completely thread through the oil drain. I never installed it because of that.
Let me know if yours reads correctly once installed!
Cincy_jro (12-10-2019)
  #694
Old 12-10-2019, 09:14 AM
cooper48's Avatar
cooper48
cooper48 is offline
This VDO oil plug/sensor fits nicely and seals perfectly. I would think that even with a shorter sensor that it would work since that sensor is immersed in oil. I will admit, though, that the gauge is not presently reading but I'm also not sure the gauge even works since the sensor was missing when I bought the MC40. My next step is to remove the oil temp gauge and have it tested and/or repaired. I'll update this post when I finish that process.
  #695
Old 12-10-2019, 09:54 AM
Cincy_jro's Avatar
Cincy_jro
Also check your engine grounds. The VDO sensor is resistance based and if you have poor grounding at the sensor threads it can read wrong. It's also possible that it's just the wrong sensor for the gauge and a different resistance sensor will be the ticket.
  #696
Old 12-10-2019, 10:03 AM
ALLMAGAutoParts
This is the gauge that you would need if it comes to replacing it. It's the same spin-lock style gauge that fits the OEM Aux gauge panel. I have a few here right now. I'm trying to finalize the correct sensor before I put together the package set which would include both gauges, sensor and a carbon fiber gauge panel that is molded exactly as the OEM was.
  #697
Old 12-10-2019, 10:17 AM
Cincy_jro's Avatar
Cincy_jro
  #698
Old 12-10-2019, 03:14 PM
cooper48's Avatar
cooper48
cooper48 is offline
Good info, thanks.
  #699
Old 12-11-2019, 11:03 AM
Green Flash's Avatar
Green Flash
Green Flash is offline
MC 40 Collectibles - MC40 Model
Sadly, we no longer have our MC40. It may be time to part with our MC40 collectibles to someone who can enjoy them. Have two MC40 models, made in England. Both are in excellent, never removed from box, condition. One of the boxes shows some wear. The one in the very good box $50, the one in the fair box $45.
  #700
Old 12-11-2019, 11:07 AM
Green Flash
MC40 Collectibles - Duffel Bag
A MINI John Cooper Works, number 37, duffle bag. $70.
Quick Reply: R50/53 The Official MC40 Owners Club
