R50/53 Power Steering Motor Went Kaboom --> set motor on fire :-(
#26
on
picked it up after work, so haven't spoken with my service advisor, but since they have the old core, can't they turn it in?
haven't called yet, but I don't quite get that charge...
#28
#31
Mine's completely dead, been driving around with no PS for about 2 weeks now. So timely of the car, right smack in the middle of mid-terms and applying to law school, with the nearest dealer in Escondido I just simply have not had the time. I'm at 46K miles now, guess it would be a good idea to get it over there before 50K so I don't need to foot the bill on my own. Sheesh :(
#32
#33
#34
Tuesday, my power steering pump kept running after I switched off the key.
I called up Roadside Assistance and asked to speak with a service tech to find out which fuse or relay to pull to stop it. Surprisingly, the customer service rep immediately connected me with a service tech. He told me that there was no fuse. The power steering pump is hardwired directly to the battery, and that the only relay in the circuit is actually part of the pump itself. He advised me to immediately disconnect the battery. (Before disconnecting the battery, make sure you drop the driver's window about 1/2 inch)
After disconnecting the battery, I came inside and started searching NAM.... After reading up on the subject, I am pretty sure that my MINI would have suffered a catostrophic fate.
Wednesday morning, I set up an emergency service appointment with Global in Atlanta. They told me to bring it down and they'd take care of it ASAP. Before I left home, I took the precaution of disconnecting the power steering pump's electrical connections. (You have to remove the PS fan to access the connectors unless you have hands the size if an infant's with the strength of the hulk.)
A couple of hours later, I had a new power steering pump and my problem was solved.
Anytime a power steering pump acts up, DISCONNECT IT! If you can't, at least disconnect the battery. The service tech told me that there is no fuse in the circuit (If there is one, I could not locate it.)
If there truly is no fuse, this is a p*$$ poor design. If anyone knows more about this high amperage circuit with no fuse, please post details.
Rawhyde
Rawhyde
#36
#37
#38
#39
Here's a how to for an oil change. I think it will help you understand.
https://www.northamericanmotoring.co...ead.php?t=4928
Etrain
16
08-05-2024 04:37 AM
07-16-2020 12:54 PM
JPMontes3
08-23-2015 01:26 AM
minipopkart
08-13-2015 05:22 AM
