R50/53 Tornado Fuel Saver on Mini Cooper S?
#26
All you'll do is impede the airflow. What it claims to do is circulate the air going into the motor so it mixes with the fuel or something along those lines. It won't "work" with a supercharger because the air goes through the SC after going through the tornado thing, so you lose any potential gain from the turbulent air.
#28
#30
something small as tornado wont shut down the car but electrical issues which i experienced got me thinking twice. you never know, i just might have to get the auto-window upper for your sake.
#31
#32
never know, that tornado might collapse under wot and enter the
throttle body, then into the cylinders.
#34
#35
#36
sorry to hear about your incidence with your dads car but when its time to go its time to go, most important thing is 'nobody got hurt'.
i hope you can read this before installing this weekend.
since i have the 'S' also, i called the tornado mechanic at the head quarters and got some important information: if you read the instruction, for turbo cars, you would need to install the tornado on the throttle body end instead of the filter. since our minis are supercharged, we must do the same way. if it is normal aspirated car than you would need to install it before the filter however ours is before the throttle.
i know there is a difference but you try it and share your experience. mpg will rise .3-.6 per gallon and the response will be better on the hwy.
upon reading all respected thoughts & opinions, how many of yous are speaking out of experience or just relying on ideology and spreading the rumors?
i too was once a non-believer on this product until i experienced it thus making me a little wiser person to not listen to all people with just ideological opinions who has not experienced it and go about spreading rumors that aint true. than again, it might be jut me......but nahhhhhhh, i see someone else concurrs with my experience. oh yeah!!!!
I'm going to cry BS but since that is not enough for you I guess I will explain it too.
Originally Posted by HowStuffWorks.com
The difference between the two devices is their source of energy. Turbochargers are powered by the mass-flow of exhaust gases driving a turbine. Superchargers are powered mechanically by belt- or chain-drive from the engine's crankshaft.
An ordinary four-stroke engine dedicates one stroke to the process of air intake. There are three steps in this process:
- The piston moves down.
- This creates a vacuum.
- Air at atmospheric pressure is sucked into the combustion chamber.
Turbo Engine, almost the same, more turbos go sans IC for the tornado to have any effect on air enterin the block, must be after the turbo.
So you stil claim it will work on an N/A engine ehh?
Well Basically all this does is create turbulance unlike the animation (just like the Simpsons and Family Guy, please don't claim those people really exist) used for marketing purposes only all it will do is slow and disrupt the flow of air. Power comes from the explosion, the spark is the same , the fuel is the same, so air is the variable, more air burns more fuel, you get more power and better efficeny (and thus better mpg). Well with a constant volume how to get more air, there is only one way, density. Spinning air does nothing to change its density, if it could cool air without dispersing it then you could make a mildly founded claim.
However this product is complete BS, the gains are placebo and driving habit effect at best.
The crowd seems to be going easy on you typically a product like this gets you 6 pages of . Don't believe idealolodgy beacuse it comes from a salesman. Get yourself brought up to speed on the science and technology used.
#37
#38
#40
I think the argument is well address in this post: https://www.northamericanmotoring.co...94&postcount=8
For simplification purposes just follow this link to referenced material. http://www.fuelsaving.info/turbulence.htm
Damn, forgot which x we are on...
Florida by birth, Gator by grace of God...
#41
So a SC engine has no gain from this because our air flow goes intake, SC, IC, engine block, the air flow gets changed up in the SC and the IC, negates anything the tornado would do.
#42
any golfers? if so, do you think a non-golfer could ever feel the way a real golfer would feel, especially hole-in-ones? or even in how people think what one important thing to remember when using the driver to tee off?
the ones who experience it would know what i got and not just think i got...
i hope you understand
#43
here's the scoop... if tiger woods used a special aid to help w/ his swing everyone would use it. hence, if race cars use the tornado then no questions asked...
but the thing is, this item in question (the tornado) is not being used by professional racers. it's a keen idea but does it work? well, you'll have to be our judge and tell us if it's working....
i believe we met at steve's auto clinic a few weeks ago... you were trying to get the AGS v.3 installed right?
my point: you have a lot of great/significant mods. why impede it w/ this contraption? the k&n pipe is smooth as a baby's behind, the alta intercooler is larger than stock, you're pulley is reduced over the stock by (insert number here)%, why cheapen all these quality mods w/ a gimmick like the "tornado"?
i say this, drive it around for 2 more gas tanks w/ this thing on. then, take it off and run it for 2 gas tanks... come back and tell us if it's really making a difference in power, gas mileage, etc...
-glen
#44
hey you... thanks for showing me your car with the dampers. upon observing your damper at work i thought it was a great mod and especially against the price. i felt what you had said about your car when i got it installed and fired it up and drove on it and wow, what a difference, just like you said it should effect. i posted a thread on this experience and needed to share, like you did to me, but some are still hard deciding on this mod that is sooooo worth its money and you know once they feel it or experience it you know they will be happy, like you did too me. thanks.
are dampers used in formula one cars or indy cars?
i dont think so. not all mods out in the market is in the those professional sport cars.
like all im trying to say is 'do you have it too?
#45
and for tiger woods, he can't even if he wanted too, theres regulation *how many pieces of clubs you can carry.
so, is there more than 14 'make your swing perfect' devices on the market or are all those celebrities just lieing, all of them?
ah yah yah, who do can we trust, hmmmmmmmmm......
#46
but back to the tornado, either way, pls do the comparison test for us... i'd love to see if the numbers are worth the install... (i don't think too many are running this, so you and ukhan24 are gonna have to be our test rats... )
#47
than why are you trying to convince others without trying it and experiencing it? some can be misleading since without experience you can be found like an idiot or tested rat if not proven to your thinking.
you state we will be the rats but this rat spoke and you did not listen. you ask of something you dont mean to consider.
from what i remember, you had the k&n HAI. can you install tornado in your cooper?
#48
#49
[quote=glnr13;1207023]i hear what you're trying to say but you have to understand that the physics of this item is not unlike a lot of golf "aids" out in the infomercial world...
i think you totally misread my comparison. if you read it again, you will note i am trying to relay a message of 'experience' or 'feeling it' and not any aids of golf in the infomercial world. are you speed reader? if not read carefully to not assume and create something irrelevant and get you stunned.
if you have read from the beginning and get my drift, i read the cons beyond cons about this product but like ive been asking, 'do you have it in your mini?
there are smart guys like you but cutting in line will when caught will get you behind the line.
if i were you without the tornado, i would tell ukhan24 to give me your expereince with it so i can compare to those rumors.
#50
show us a comparison of a before and after...
correct, i have the k&n hai. i don't swear by it... i just personally like it. i like the sound, i like it's performance on the highway. the hai has greater heat soak than any intake mod, i know it's pluses and minuses...
and no, due to the fact that it's strapped onto the TB i can't get the tornado on. and to be honest i'm not convinced of the tornado's performance... this is why i was suggesting that you show us what it can do.
im not trying to egg you on or push your buttons, im honestly curious as to your results... by calling you guys test rats i meant no insult... sorry if it was taken that way.
since you feel that i'm trying to "cut in line" i'll step out of this thread... sorry for bothering you
