R50/53 Driver Side Door Ellipse Buzz
Old 05-04-2003 | 08:14 PM
fins4284's Avatar
fins4284
I searched this forum and have yet to find a definitive fix other that have the dealer take a shot at it. Here is my issue: When driving on rough roads or in low gear there is a buzz coming from the ellipse on the drivers side door -- not a real loud buzz, but just enough to **** me off. I know it's the ellipse because when I lightly place my elbow on it, the buzzing stops. Have tried squeezing folded up electrical tape in between the adjoining parts where I think the plastic-to-plastic noise is coming from but am still getting the buzz. My dealer is 250 miles from me. Anyone have much luck in eliminating the buzz themselves? THE CONSTANT BUZZ IS DRIVING ME NUTS!!!!!
Old 05-04-2003 | 08:17 PM
vdubdoug's Avatar
vdubdoug
I have a similar issue. can't figure it out
Old 05-04-2003 | 08:23 PM
Calvin77's Avatar
Calvin77
I have the same exact buzz, haven't fixed it yet but i've noticed that if I lightly touch the screw closest to me on the ellipse, the buzzing stops, so I'm thinking that a quick tighten of that screw should cure it.
Old 05-04-2003 | 08:27 PM
fins4284's Avatar
fins4284
Thanks, but have tried combinations of loosening and tightening the three screws attached to the ellipse but still no luck! Surely someone in this forum has figured this out
Old 05-04-2003 | 09:00 PM
fins4284's Avatar
fins4284
TTT. Unitl I get an answer!
Old 05-05-2003 | 06:24 PM
fins4284's Avatar
fins4284
Found this in Mini2. I think it will solve our problem, folks:
Door Buzz Fix
Looks like a simple fix. I'm gonna give it a try this weekend.
Old 05-05-2003 | 06:29 PM
Sarcux's Avatar
Sarcux
My passenger door did this. Its actually the panel itself. I took 4 of those rubber O-rings that you put in between a spray nozzle and a hose, used a screwdriver to pull the panel out a bit, and put two on the bottom, and two on the side. Its unnoticeable, and worked great. Hope that helps.
Old 05-05-2003 | 06:37 PM
fins4284's Avatar
fins4284
Hey that sounds alot easier than the one from MINI2. I'll give it a try first. I'll try anything!!!! Thanks
Old 05-05-2003 | 08:23 PM
GBMINI's Avatar
GBMINI
I just did the fix similar to the MINI2 post this last week.
Took each panel off and ran adhesive backed felt around the edges of the panel and over each clip, and where the screws go through.
So far I cannot hear any buzzing, vibrating or any other noises that had irritated me so much before.
There IS some very slight felt on the door edges already so maybe it is the clips that vibrate, or maybe there is not enough around the edge ... but anyway if you take the door panel off, you might as well cover everywhere.
Door panels are NOT difficult to remove; just take care not to scratch anything.
Old 05-06-2003 | 12:47 AM
Sarcux's Avatar
Sarcux
Really? I couldn't get my door panels off for some reason. All the paneling in my car has been stubborn, from removing the rear seats (which I'll never do again, they didn't go back in right, and scuffed up the plastic bigtime. The driver side clip broke, so I have duct tape around the prong to keep it from rattling... just like you have to do in a Jeep after awhile, lol.) to trying to get the passenger kick panel off to install my rally lights' relay. That was a pain to install without taking the panel off.
Old 05-07-2003 | 06:51 PM
fins4284's Avatar
fins4284
Wooooohoooooooo! I finally got around to removing the door panel and stuck adhesive felt in every conceivable part of the panel. Took her out for a test drive and no buzzing! Let's hope it holds up. Cost: $10; total time spent - 1.5 hrs.
Old 05-12-2003 | 06:16 PM
fins4284's Avatar
fins4284
Door Buzz Update:
They came back. Pulled the door panel and taped up lock rod, placed tape over the female receptacles of the door panel pins and the @#$% buzz is gone! Am getting ready to do same to the passenger side.
_________________
I'm growing older but not up. My metabolic rate is pleasantly stuck - J. Buffett
ej
09-28-2015 05:41 AM
RACEnSK8
08-31-2015 01:08 PM
chappybmode
08-24-2015 09:58 AM
one73ronin
08-19-2015 12:36 PM
messyjesse96
08-12-2015 05:51 AM
Quick Reply: R50/53 Driver Side Door Ellipse Buzz
