R52 Break IN Steady Speed
My 2008 Non S Mini Convertible should be here very soon as it's on a boat. From what I have read normal break in is 4500 max RPM speed upto 90-100mph. but vary the speeds. Any thoughts on when I can get on the interstate and set the cruise to 80mph for 3-4 hours without varrying the speed. Thanks in advance & Happy Thanksgiving to ALL!! Mike in Fl.
The late 07 and 08 manuals aren't online yet, but yeah 4500 RPM/100 MPH max- after 1200 miles you're allowed to slowly work up to higher RPMs and speeds.
Luckily for me, traffic on my commute is a mix of open freeway and stop and go, so I was never doing the same speed for more than a couple minutes. When the freeway opened up, I'd change gears every couple miles to vary the RPM a bit, but I don't know how well that would work for a long drive.
I was under the impression that the actual engine was broken in within the first 20 miles. The break in period is for the clutch, brakes and tires.
During the first 20 miles, the piston rings and cylinder walls are what need to be broken in properly. The cam, and crank shaft require little to no break in.
This website explains the whole idea/process. It yeilds better sealing piston rings ergo more power with less blowby. The principles apply to all 4-stroke internal combustion engines.
Engines broken in with his process were stronger than those using the conventional method. Alas our engines are usually past this threshold long before we get them. If your is not, do yourself a favor and read that article.
If I ever need new rings in my MINI or get new pistons, I'm using Mototune's method to break it in - after a good cylinderwall hone.
I'm glad I did some good heavy acceleration straight to 4500 on the first freeway onramp.
Interior/Exterior Unboxing Video of Sneed4Speed R53 Brake Cooling Kit
Gremothra
09-09-2015 08:42 PM
09-04-2015 09:10 AM
SneedSpeed
09-02-2015 05:34 AM
