R52 Clunking noise when accel or decel?
My 05 Cooper S Cabrio has developed a bit of a clunking noise since taking out out of winter hybernation this spring (approx 22K miles). Whenever I accelerate or decellerate, I hear a clunk coming from what seems to be the right front of the car. I checked the sway bar support link. Motor mount and bushings seem OK.
I can't reproduce the noise while not driving, which makes it frustrating. There does seem to be some play in the front right wheels steering linkage that I can get to make a small noise. The play is minor, but it's the only part up front I can get to make anything remotely like the noise while parked.
Anyone have any other ideas of things to check? A new steering arm is pretty pricey, and I can only find the part as a front steering rack assembly, not just the right arm. Not sure if I'm using the correct terms. Hoping someone else has run into this and figure it out. The noise drives me nuts. :-(
Thanks!
Lee
Thanks!
Lee
I didn't see any leaks. I just grabbed the engine and tried to "shake" it a bit. I'm leaning this way though, as I believe I've heard it a couple times now upon starting the car. I think that would rule out the steering.
Are there better aftermarket mounts that folks would recommend if I'm going to go through the trouble of replacing this? I've never had a car blow an engine mount with only 22K pampered miles on the Odometer. :-(
Regards,
Lee
Regards,
Lee
As I recall, my engine mount started leaking around 30,000 miles. Many fail early in life. If you do not see a black stain below the mount it probably has not leaked yet. There are other engine and transmission mounts but they are rubber not fluid filled.
Texas Speed Works (TSW) makes an aftermarket mount.
http://www.txwerks.com/servlet/Detail?no=331
The TSW mount is $200 compared to the stock at $75 but you will not need to replace the TSW mount after another 30k miles or so.
Well, my mount is leaking now, so it's definitely the culprit. Trying to decide between replacing with the stock mount or a solid aftermarket mount from TSW.
I would go the TSW route. Their mount was still in development when I had to replace my leaking mount so I had to go with the stock. I plan to replace the stock mount with a TSW mount before this second mount starts leaking. It took me a long time to clean all the black goo off the car and I do not want to do that again.
unxpectederror
10-22-2015 12:16 PM
Miniwaukee
09-29-2015 09:22 AM
