R52 Time for a new clutch!!!
Old 02-08-2013 | 01:01 AM
Hyper26414's Avatar
Hyper26414
I have a 2008 Cooper S. I have 15% pulley and a cold air intake. I was wondering which clutch I should purchase.
Old 02-08-2013 | 07:15 AM
Helix13mini's Avatar
Helix13mini
Go with the stock clutch unless you have a specific reason for a high-performance clutch (like you autocross or drag race, and don't mind replacing clutches more often).
Old 02-08-2013 | 08:16 AM
Hyper26414's Avatar
Hyper26414
I think I would like to replace the clutch less often. I was trying to find something a little longer lasting. Also is a solid flywheel better than the dual mass fly wheel?
Old 02-08-2013 | 08:37 AM
Helix13mini
Stock is the longest lasting. You can do a flywheel conversion kit (HMS 7018) which will reduce your cost if you have the dreaded 'Chewbacca' chirp upon start-up.
Old 02-08-2013 | 08:46 AM
Hyper26414's Avatar
Hyper26414
Yeah it definitely has a squeal or a chirp as I take off from a red light or stop sign. How long will the clutch last in this condition? I just want to know how much time I might have. I would love to wait until it gets warmer out. I have just over 40,000 miles on it.
Old 02-08-2013 | 08:54 AM
Mini-mize-Me's Avatar
Mini-mize-Me
That is one beast of a job to change the clutch. Are you replacing it yourself?
Just curious as to the length of time to do it as mine will be needing a clutch soon.
Old 02-08-2013 | 09:02 AM
Hyper26414's Avatar
Hyper26414
I plan on doing it myself. I have no idea how long it will take. I hope to knock it out in about 3-4 hours.
Old 02-08-2013 | 09:18 AM
Mini-mize-Me
From what I've been told its a 12-14 hour job which requires removing the front bumper. If you can do it in 3-4 hours, YOU DA MAN!
Old 02-08-2013 | 09:42 AM
Helix13mini
You'd be a hell of a wrench if you could do it in 3-4 hours. It's impossible to tell how long it will last: could be a day, could be a year.
Old 02-08-2013 | 10:20 AM
DixonL2's Avatar
DixonL2
Most of the "chewbacca" noises are a VERY early indicator, mine lasted another 20kmiles and even then was strong, it was a bushing that failed, dealer helped me out at 65k.
Clutches are rough, you have to take the car to "Service level 1", which means removing the bumper cover, bumper, radiator, and pulling the condenser out of the way, before you're even at the point you can BEGIN the clutch job! While in there, check all vacuum/boost hoses (good time to install the boost gauge!), perhaps consider re-oiling the supercharger, replacing the water pump, and checking/replacing the t-stat.
But you shouldn't have to do that for another few 10's of thousands of miles, barring drag racing or abuse or bad luck!
Old 02-08-2013 | 11:44 AM
MINIdave's Avatar
MINIdave
Not to disregard anything Helix is saying, but I recently installed a Valeo clutch in an '02S and the owner LOVES it. It came with a solid flywheel and everything you needed to change it, and was about half the cost of an OEM replacement. We got it from Way Motor Works.
The owner reports that it reminds him of his old Honda, light, positive engagement and very smooth.....he has a 15% pulley too.....
Old 02-08-2013 | 11:50 AM
BRracing's Avatar
BRracing
i can get you a great deal on any Flywheel or clutch you want! OEM or Aftermarket! PM me
Old 02-11-2013 | 09:11 PM
Hyper26414's Avatar
Hyper26414
What are the Pros and Cons of going with the solid flywheel? Besides the cost.
Old 02-11-2013 | 09:15 PM
WayMotorWorks's Avatar
WayMotorWorks
Vendor
We've had great luck with the Valeo conversion kit.
The pros are it is cheaper, a little lighter by a couple pounds, and the flywheel is solid so it won't fail like the dual mass.
Cons, the only one they claim is it is louder. But I can tell you I've installed 30+ of these and you really have to pay attention to notice anything different about it.
andrewjg1994
01-29-2021 07:45 PM
eliseo1981
01-28-2021 02:45 PM
Teh
06-13-2018 02:59 PM
bjcarter2
08-31-2015 04:03 PM
Colt45Magnus
08-12-2015 06:43 AM
Quick Reply: R52 Time for a new clutch!!!
