R52 MCConvertible "Squeek": Help!
I recently traded in my two-year old BMW X3 for a 2006 MCC manual chili red, black, with various options. I've absolutely enjoyed each of the now 2k miles the mini and I have driven these past two months. I thank so many on this board for the help in deciding to order the car, what to order it with, and aftermarket items such as Ian's auto-up circuit, and european parcel shelf.
I have one nagging issue in an otherwise fantastic car. There's a "squeek" that eminates from behind the driver on the upper left side, up somewhere where the rear window and drivers window meet the convertible top. This squeek is consistent and obvious. Seems to be worse with the colder weather here in New England. Do any Convertible owners have any insight or knowledge to share on the cause and solutions?
Thanks in advance for any help.
This is going to sound funny. I have a similar rattle/squeek on my right side. The tech at the service department said it is coming from an "anti rattle" bolt specifically designed to prevent such things. They can fix it. I haven't done it since it requires the soft top removal and I haven't had the time yet.
Mine is super squeeky on the right rear window and top. I thought it was the seal between the front and rear window seal but noticed it still squeeked after the front window was down. I then realized it was between the top and rear window. If I lower the rar window slightly it stops. Needless to say very annoying in an otherwise perfect car.
I get the same squeaking sound from both sides, from the same location as you describe. I will probably complain about it pretty soon - I've had the top down often though, so I don't hear it much. I also get a bit of leaking in touchless car washes from the same spot where the squeaking is coming from.
It is pretty annoying - hopefully they can find the problem.
I also have the crescent scratches on the rear windows. I was hoping that wouldn't happen, as my car was a late oct-early nov. build, but they are there.
My wife's MCc was quiet until they replaced the top (twice) - then it started to 'rattle' from both sides like cables bouncing around inside. On our last service visit, I complained and they fixed it (they had to peel back the top to get to the mechanism). Unfortunately, the rattle is back on one side and will be brought up with our SA on our next visit.
The top used to squeak something terrible when opening / closing, but that seemed to go away after the top replacment.
k
k
Wow! You guys are great at figuring out where the sound is coming from.
I have three squeaks:
- When the top is going up/down is squeals from somewhere in the back.
- When I put my drivers side window down on a cold day it squeals.
- When I apply my brakes softly on a winter day they sound like the pads are wasted (but they are not).
Squeak
For about three weeks, I had a rear squeak similar to the one described above (only with top up and on cold mornings). It cured itself before cool season was over so I am hoping it is solved. I had another car with a squeaky dash and it could not be solved with multiple trips to the dealer but after 1.5 years it fixed itself. Good luck!
Squeak
Top and Transmission
Well, the car went in to have an oil change and I mentioned:
1. the weird top wear spots and the top alignment issue - it does not close all the way on the passenger side.
2. hard shift of the automatic transmission from 1 to 2.
I get a call the next day from the dealership saying that MINI is putting a new top and that they are evaluating my hard shifting further. Next day, call sys I am now getting a new transmission as well...
I dropped the car of Wednesday of last week and got it back today. Top is new, transmission is new, but top is still out of alignment.
2 questions:
1. has anyone had the automatic (CVT) transmission replaced with less that 40K miles?
2. Anyone knows how / is there a way to adjust the top?
Nano
2 questions:
Nano
