R55 emergency fuel cutoff
All cars made today have an emergency fuel cutoff that cuts off the fuel when the car is in an accident. The purpose being to keep the car from catching on fire.
However, if the car is not damaged too much you may be able to drive it home, or off the road. In any case you will need to turn the fuel back on.
Does anyone know where this valve is located? I can't find it in the Owner's Manual.
it's not a valve per se. Cars in the States have an inertial fuel shut off solenoid. Activation of the unit does not require air bag deployment. I have seen a car that blew out a right rear tire set off the switch. The reset is usually in the rear of the car. It is usually a red push button.
Having said all this, I don't know where the switch is on the mini, nor do I know for sure the activator.
Capt. Joe
FWFD
Capt. Joe
FWFD
Capt. Joe
FWFD
Capt. Joe
FWFD
IQRaceworks
53
06-28-2024 07:29 AM
HK_MCS
R58 :: Coupé Talk (2012+)
10-04-2015 08:03 PM
dutchhome
09-30-2015 07:17 AM
