R55 Roof rails vs. roof rack
#105
Meanwhile, for photos of the roof rails with the new MINI cross bars check out this thread: https://www.northamericanmotoring.co...d.php?t=157932 or you can go directly to this set on my Flickr page: http://flickr.com/photos/otra/sets/72157609631424061/
#106
#108
Please DO NOT post the same question in more than one thread. THis will get you in trouble with the moderators and also upset may of the other people here.
Post your question once and you will get an answer.
Also i suggest you read the forum rules at https://www.northamericanmotoring.com/guidelines
#113
#114
Well, if you're talking about the factory installed roof rails you should take a look at this thread: https://www.northamericanmotoring.co...il-option.html.
When you ask what the maximum distance is that you can spread the cross bars...well, I'll see what I can find out tomorrow morning. Meanwhile take a look at my photos on Flicker http://www.flickr.com/photos/otra/se...7609631424061/ and you'll see that there's quite a bit of room. You will probably have to remove the antennae though.
#115
Thanks Otra, those photos really helped. According to Yakima the ideal gap between the front and rear crossbar should be 30-32 inches for longer objects like sea kayaks. Can I assume I can place the crossbars anywhere along the length of the rails or are there factors in the design that would reduce flexibility. The antennae would not have to be removed. The kayaks are 23 inches wide and are placed over the passenger and driver positions of the car, the antennae would pop up between them. Also the rails run wider than the roof line just a little bit to hold the outward kayak saddles.
Appreciate the links and the measurements when you can get to them.
#116
Coney, I'm going to answer this on the other thread https://www.northamericanmotoring.co...-option-2.html ...so as to keep the discussion in the "right" right place.
patsum
26
05-29-2021 06:29 PM
techgearpro
07-23-2019 07:09 PM
