R55 Attaching rear license plate to a Clubman
This is going to sound silly but...how do I attach a license plate to the rear of my Clubman? I purchased my car out of state without plates, and I can't seem to find any information on what size screws I should use. Here's what my rear plate area looks like:
There are 4 black self drilling screws holding this plastic base to the bumper. My license plate holes line up with the 4 unthreaded holes on the plastic base (and not the 2 metal threaded holes on the upper portion of the base). I took out the 4 screws that attach the plastic base to the bumper, and found that the base is also secured at the top to the underside of the bumper lip.
Am I supposed to use these 4 screws to secure my license plate to the plastic base? The 4 screws have bored through the bumper already, but since the entire area is covered by the plastic base I supposed 4 more holes wouldn't matter much. Are should I just a similar set of self drilling screws?
I've been searching all over but can't find an answer to this simple question. How did you attach your rear plate? And what are those 2 threaded screw holes for?
Texas plates do NOT line up with the threaded holes. I used supplied self-tappers in the plastic. Not real happy with that, so I may put t-nuts behind the plastic panel. I hope to install a minidomore hitch when it is available, and its receiver apparently will exit behind the license plate - I'll be R&R-ing the plate often to use the hitch.
07-16-2020 12:54 PM
nismo4life
11-04-2015 09:18 PM
Minibeagle
08-13-2015 10:00 AM
