R55 New roof rack base support for vehicles with roof rail option
#26
Although we've been using the roof rails with MINI's cross bars, I hadn't remembered to take any shots with the Thule "Excursion" box on top so here's a photo: and a link to several more here: http://www.flickr.com/photos/otra/se...424061/detail/
This Thule box is shorter but has quite a bit of depth and holds a number of suitcases, boogie boards, beach chairs and whatever else you might need to bring along on a trip.
#27
Taken from the other thread:
Just went out and measured. It seems that could have a spread of about 42 inches between the cross bars, given that the feet of the cross bars take up about 3 inches, and you'd need to make them fit on the the rails before they become thicker and curve down at the ends. The crossbars are 35 inches wide.
I'm not quite sure if I am answering the question the way you want or not. Please let me know if I can be more specific or take anymore photos, etc., OK?
Thanks Otra, those photos really helped. According to Yakima the ideal gap between the front and rear crossbar should be 30-32 inches for longer objects like sea kayaks. Can I assume I can place the crossbars anywhere along the length of the rails or are there factors in the design that would reduce flexibility. The antennae would not have to be removed. The kayaks are 23 inches wide and are placed over the passenger and driver positions of the car, the antennae would pop up between them. Also the rails run wider than the roof line just a little bit to hold the outward kayak saddles.
Appreciate the links and the measurements when you can get to them.
#28
#29
Glad to be of help - that's what makes a place like NAM so worth while....well that and being able to look at everyone's MINIs.
So your kayaks will stick out past the edge of the car, along with the Yakima cross bars? Just be sure they don't stick out right where someone will crack their skulls
P.S. I hope I made myself clear about the 42 inches being the spread from front to back as to where the cross bars could be attached to the rails, and the cross bars being 35" across the top of the Clubman's roof.
#30
Yep, the spread from front to back between the bars is about 42 inches max. The width across the roof between the rails is 35 inches. Got it! Thanks again!
#32
Otra, thank you so much for all the posts and pics on the rack! You really are a leader in the field of the Clubman roof rails rack : ).
It is my understanding that this rack is made by Thule. Can anyone confirm? Are the bars the same as the Thule Aero bars? Can then all Thule products be used on the rack? Are adapters needed? Thanks, I'm ready to buy but want to make sure that I look before I leap.
Thanks!
Thanks!
#33
My box is a Thule box and it fit just fine without any adapters. I don't own any other other options for a roof rack. This is the same Thule box we have used on our Volvo's Thule cross bars on its factory roof rails.
I don't know that MINI will come out and say that their MINI cross bars are made by Thule, but you should be able to speak to the Parts Manager at your dealership and ask about how it works.
If you want send me a PM and I'll give you my dealership's Parts Manager and you can ask him - he's very helpful.
(If you got one of those 10% discount post cards from your dealership (as I did and have again) be sure to ask about using it! 10% is 10%.)
OK here are some more pix - and you can check my Flickr page for cross bar OCD, too. http://www.flickr.com/photos/otra/se...7609631424061/
#34
Thanks!
Thanks!
That said the cross bars are very close to the same dimensions as the Thule Aero Bars but not exactly the same. They are close enough though that 99 % of the items made for the Thule Aero Bars will fit. I only remember one bike tray not fitting and if my memory serves me correlty that same bike tray had to be sightly modified to fit the Aero Bar as well even though Thule said it fit.
08-12-2015 01:24 PM
Accessory Products
08-11-2015 12:59 PM
08-11-2015 12:58 PM
Accessory Products
08-11-2015 12:37 PM
