R55 Where to get the tread screw that hold donut spare tire to the well?
I got a Cobalt's donut spare into the tire well a while back is it fit fine, but I would like to know where to get the big thread screw that secure the donut to the well in the middle like other cars has. The donut will bounce ups and down every time I cross a ramp and I would like to use the screw to hold it tight. Do I have to go through a MINI dealer?
36-10-6-782-325 - Mounting Screw Spare Wheel
36-10-6-781-466 - Spare wheel retainer
Both avaliable from your local mini dealer, OEMPARTS.com or CLasis Mini in Ohio will ship you the parts.
Question for you. Does the spare tire you bought fit over the brakes?
I have not found one that does fit over the brakes and also in the spare tire well.
I do not have a spare as of yet and probably will never as i do not mind the ride of the Run-Flats and the space where the spare fits is full of other stuff now.
But the question is now to Prost. Where did you buy your spare.
Good thought. What length bolt did you buy?
You need two pieces.
thanks for the info.
Moderator
No, the space saver spare that I got from Mini does not fit over my brakes (on my Clubman S)....so if I have a front that goes flat I have to move one of my rears to the front. Per my dealer, Mini does not offer a space saver spare that will fit over the S brakes. The space saver spare that I have fills the hole in the trunk.
Also, since I bought a Limited Slip Differential, I would have to do this anyway because I could not run different size tires on my drive wheels without damaging the Differential. If you don't have Limited Slip you don't have to worry about this.
