R55 Help! Wiring driving me nuts
on
So I purchased a quad lights set up from VIP and installed the bracket and new grill without a problem(the middle bracket was quite a pain with tightening though). Anyways, I was looking at the instructions to install the Hella 500's and I'm absolutely confused. I have a pair of driving lights that I would like to hook up to the brights and a pair of fog lights that I would like to hook up to its own switch. How do I go about doing this? I have no idea where anything is(this includes the bright wiring or whatnot) No idea where to even start! Someone help? Color coded instructions would really help including any pictures or descriptions of where and what the parts look like.
on
This car is fully computer controlled it is not like the older cars where a switch was a switch. The switches in the Mini control a line that goes into a computer and the computer outputs the correct signal to the light, horn, wipers etc.
If you can tell me more about which switches you want to do what i can possibly help you or tell you it will not work.
So if i understand you correctly you have four (4) extra lights that you want to hook up.
One pair you want to come on when the High Beams are turned on.
The other pair you want to come on when you turn the fog lights on.
Is this correct?
What state do you live in?
Do you have the front Fog Light Switch in your car? (center console switch position 2nd from left.)
After these questions answered i can help and may have more questions.
Is this correct?
on
on
on
Unfortunately the kit I have isn't OEM and instructions assume that you know some basic electrical wiring in a vehicle. Either way, I opted to use a circuit tester with a sharp point to poke through the different wires to test the brights circuit. Minimal cut and I'll just tape it back up.
Wohnson89
06-10-2020 04:53 AM
ryGuyMCS
10-20-2015 02:24 PM
JHolland
08-13-2015 10:47 PM
minipopkart
08-13-2015 05:22 AM
