R55 LSD vs EDLC
Tom, I see no one has replied to your question so i'll give it a try. I run the standard LSD in my Club S. I see no reason to spend more, if it is more for the electronic unit. In the long run the LSD may prove to be less problematic. It definitely can handle any "spirited" driving. I can't believe that all the Minis that are raced or auto X'ed have the "E". I think you'll be just fine with the LSD. Good luck and enjoy. Dan
The only reason that they put the ELSD into the JCW (I think) is that they didn't have an LSD to match the upgraded powerplant and transmisson of the Gen2 JCW. A lot of power will be lost in the turns by applying the brakes to control individual wheel spin. A true LSD would be far superior in a performance environment. I'll bet that a standard LSD will eventually be available for the JCW.
I am worried you may be right.
Torque steer is an interesting critter. After I added the JCW package to my '02, I had a very uncomfortable amount of torque steer. I then added an OEM 6 speed with LSD (mostly to get the closer gear ratios). Torque steer virtually disappeared. Some people complain about excessive torque steer with LSD & others complain about it without. I'm wondering whether it depends on how something is set up (perhaps alignment) on each individual car that might account for it.
One of the greatest benefits of having the LSD over the e-diff, is that the LSD is always active. One example of where this is beneficial is that you can have DSC on while the LSD is working. The increased traction gained from the LSD, means that even with aggressive cornering, you can maintain traction longer before DSC kicks in (great for public roads). A mechanical LSD almost gives the feeling of sling-shooting out of corners, but if things really get hairy and you have DSC on you know you won't end up in a ditch. My understanding of MINI's EDLC is that you activate it by turning OFF DTC and DSC. And although EDLC works very quickly, it is still a strictly reactive system and does not have the option of keeping a safety-net with stability control on.
The mechanical LSD is sourced from GKN Driveline (or at least the 05-06 was and I'd assume the R56/R55 is the same) which gives a 30% lockup rate, is pretty-much "maintenance-free" and has very little driveline harshness (compared to clutch-type differentials.) If this "Super LSD" exhibits 1.5-way characteristics the LSD would also have some traction advantages when lifting off throttle or braking although my guess is that it is a safer 1-way system.
One of the disadvantages of the MINIs mechanical LSD at a dry track is that if one wheel becomes unweighted (comes out of contact with the ground) it acts like a standard open differential and you'll get wheelspin. Additionally the EDLC does have the advantage of a lock-up rate up to 50%. The LSD is going to feel more progressive on a dry track, but my guess is that with the greater lockup potential, the EDLC may actually be better in slippery situations (rain and snow.)
I ordered my 09 MCS with both LSD and DTC (which comes with EDLC)-- does anyone else have this setup? I don't think I realized it was a bit of a redundancy at the time of ordering... I am wondering how this will all work out with my car!
If anyone has both on their car I would love to hear about it!
I dont like all this new EDLC rif raff... why spend more money for an open diff? which is what your doing, and then tack on another goofy electronic do dad that smokes the inside brake pad... what a waste of money!
sounds like a easier way for bmw to reduce costs and increase revenue...
i like my lsd, works great...
My interest in the LSD or the ELSD is from the standpoint of driving in snow. Will either or both offer any significant advantage in putting power to the ground in slippery snow conditions? My house is a the top of a couple of steep hills, and getting up them in snow is pretty dicey...
What I really need is a an AWD Clubman.
I test-drove an LSD equipped pre-sportpack '09 last December in pouring rain. The wheel noticeably slipped when I was accelerating out of a turn.
Thus I opted for the sport pack that comes with EDLC and got to play with it a lot in the rain once I got the car. IMHO there is virtually no perceptible wheel spin when coming out hard out of a turn on a wet road.
I'm pretty damn happy with the gadget - works as advertized and was pretty much free since I wanted the other pieces of the sport pack anyway.
Zoltiz--
That's very useful information... thanks. I'm wondering if that translates into better straight-line uphill traction in slippery, snowy conditions. Also, the 6MT Clubman S that I test drove had LSD, and suffered from intense torque-steer... Under hard acceleration from a stop, the steering wheel really tried to wrench itself from my grip. To me, that's a pretty serious handling flaw.
I've owned several FWD supercharged 4-bangers (toyota/scion with TRD blowers), and compared to them, MINI has no torque steer in a straight line on decent road.
Pick a rainy day and drive both EDLC and LSD Coopers - that's the only way to really know for yourself.
As far as traction in snow is concerned, with DSC/DTC off, EDLC is still active, so it should help, especially since EDLC is not controlling engine power.
09-28-2015 09:13 AM
