R55 Strange Noise on JustaClubman
I have an 09 JustaClubman, purchased in February of this year. When I shut off the car, I will hear a poof sounds every 15-20 seconds after I shut off the car, almost like back pressure from the exhaust. Eventually, it will stop, but is this normal? I read somewhere else this is the gas tank bleeding pressure. The strange thing is every once in a while, I will hear a similar noise at a stoplight. Other than this strange noise, the car drives and sounds fine. Any thoughts?
It is coming from underneath the car, towards the exhaust. I can
definitely hear a fan running underneath at the same time. Once the car stops making the noises (which is usually a double poof noise), the fan shuts off as well.
I just did a search, and it seems like these gentlemen in the Cooper forums have been experiencing these noises as well.
https://www.northamericanmotoring.co...hutdown-2.html
I have a 2009 Mini Cooper S and I've heard what I think is the noise you describe. When I took my MINI to the dealer for the new intake manifold design (frozen throttle body valve; caused low power on cold startups), I asked that they check this noise. My best description of the noise is the noise a car makes when it's parked on an incline and you apply the parking brake, then release your foot from the brake pedal to get out of the car. The car "creaks" a bit, almost as if the parking brake isn't quite holding. The odd thing is that the MINI does it on both inclines and flat ground and does it intermittently. The MINI dealer found no problems with the brakes and said to just "keep an eye on it" and see if it becomes more frequent. *shrug*
EDITED TO ADD: I forgot to mention that I have a 6 speed manual transmission.
I had talked with my mechanic about this when I first got the car and he was telling me that it's the gasses/exhaust system cooling down and letting out pockets of air. Mine won't happen if the car hasn't been able to warm up (3 mile runs wont let it happen). If I'm on it and then come to a stoplight, it sometimes happens (has time to cool a little).
As for the fan noise in that region; that is the fuel pump priming itself. Kinda crazy that it primes itself after being ran and lasting for so long sometimes, but thats what it is. It is on some threads on here
I get the same noise as well, so we are all saying this is just normal? dont know why it would ONLY happen in a mini you would think if this was it that other cars would have the same noise. is it normal to happen so often my 09 justacooper does it about 11 times everytime i shut off the car......seems like it would only need to do it once.
unxpectederror
10-22-2015 12:16 PM
Miniwaukee
09-29-2015 09:22 AM
