R55 How to disable the Headlight washers?
But I will look into it to see if it can be done for you.
Where I live nothing (snow,dirt, sludge, etc) ever gets on the lens. In the sweltering - Houston Texas area the only thing the washers do is water spot the rest of the car. :(
I will post back here when I have had a cahnce to check the wiring diagrams and the hose connections.
No they may be required by most European countries they are not required by all as not all European countries subscribe to ECE Regulation 4.
As for the manufacture of them it is definitely to MINI's advantage to only make one unit.
Hey I agree, all they really do is spot my car all over. In fact so do the windshield wipers sprays, I never use them in any car I have ever owned. Like you though, I am blessed with a climate that doesn't require it. SoCal/Vegas. :-)
A much easier way to turn them off is to remove Fuse 3 in the passanger foot well fuse block.
Just to let you know F1 is an empty slot F2 is a 20 Amp fuse and F 3 is a 30 amp fuse. I pulled mine out yesterday and the head light washers have not come on since. Put the fuse back in this afternoon and the first time I used the windshield washers the lights got washed as well.
Also of note is that the wiring diagrams show that nothing else is connected to this fuse.
Just disconnecting wiring in this car can be dangerous you never know what else the computer is doing with it. Also getting to that connector is rather difficult as it is on the side of the washer tank behind the inner fender well.
Thanks for the info, just removed fuse 3. I live in TX and headlight washers are not necessary down here.
09-29-2015 12:17 PM
09-29-2015 12:16 PM
09-29-2015 12:11 PM
