R55 Help on Warning Lamp
2008 Clubman, yesterday the brake light came on over the steering wheel and stayed on. I know what that means, but now everytime I start the car I get a red mini on a lift over the steering wheel, goes off a few seconds but can't find what this light means-again it's a mini on what appears to be a mechanics lift...
on
Two things from the manual
Page 133 of the owners manual: If ABS light and Lift icon
Indication US Models - Vehicle electronics failed.
You cannot continue your journey. Contact your MINI dealer.
Page 134 of the owners manual:
Lift Icon in red:
Have the system in question checked without delay.
Starter Failed
Ignition malfunctioning
Lighting system failed.
Lift Icon in Yellow:
Control of brake lamps failed
Fuel supply malfunction
Lift Icon in red:
Starter Failed
If your red brake light(the word brake) stays on and you have a red MINI icon on a lift when you startup then it's just reminding you that your brake wear sensors are tripped and you need a brake job. The dealer will reset the lights or you can do it yourself if you plan on doing your own brakes.
Guest
Posts: n/a
TIA
Joe
OK so my Brake light came on and I replaced the rotors and pads at my local mechanic. the light is still on and the mini dealer which is over an hour away wants $65 to reset the light. Is it possible to rest myself? my mechanic has a scan toll but not sure it can do a flash reset. Please help save me time and money.
TIA
Joe
TIA
Joe
http://new.minimania.com/article/236..._Service_Light
OK, they do not have to do that, But you will need to order a Brake Sensor, because once it's tripped, it's useless. Then there is this.....
I did my own brake job as it was very very easy.
62 dollars in parts.
Resetting will work from the trip computer (little protruding pin ****) on tach.
Hold it down after your work is done and you will get into menu to reset the next brake service.
Worked on my r56 Cooper.
