R55 Water Pump
Water Pump
Hello! We are the proud owners of a hot chocolate mini Clubman and have loved every minute of it. This week, though, we ran into some trouble. Being winter here in Ohio, we turned on the heat but to no avail. The heat was at times just cold and other times it was alternately hot and cold. The Mini dealership in Cincy did a diagnostic and informed us that the water pump has gone bad and needs replaced. What's most unfortunate is that we're 1,000 miles over the power train warranty. When we priced out the cost of the water pump at some independent parts dealers, many of them said they don't carry water pumps for 2008 minis simply because they're not supposed to go bad that quick! I'm just curious if anyone has had a similar experience with their water pump going bad or if this is an isolated case. Thanks!
kevin
kevin
Well, before you go the dealer-suggested route of replacing parts, check the coolant level. A number of folks here on the forum here have been reporting no heat out of the heater when the coolant level gets low (which it seems to do more frequently than you'd expect out of a relatively new vehicle...).
If the level is low, you'll want to get yourself some replacement coolant from the dealer or some other source that sells the BMW bluish-black coolant (do NOT use the older green or newer pinkish-orange coolants; they are incompatible with the MINI). In a pinch, you can use distilled water to top off the level, but if the level is low enough to rob you of cabin heat, it's probably too low (especially this time of year, with temperatures at or below freezing) to top off with water alone.
I'v been wrong before but never heard of common coolant not being compatible with the mini, do you have a source for that? Also in a sealed system the water level shouldn't change much if at all.
I would expect if the common (green or pinkish-orange) coolant mixtures were compatible, BMW would have approved them or just used them to begin with. But that's more-or-less speculation on my part, supported mainly by the fact that the color of the BMW coolant additive is significantly different from the other common coolant additives (presumably so they don't get mixed up).
I guess I've got no good way to explain it other than to say it really does happen...
Yeah, that would point more toward a component failure of some kind...
You may want to check with another dealer, they might do a water pump swap. Don’t know if this is a recall but I had this problem at about 10,000 miles. They said they knew they had issue with the water pump seal going bad, mine is an 08. First sign was low coolant level and I heard what sounded like water swooshing around the dash on the passenger side when I taped....
elverado
01-18-2022 02:51 AM
patsum
26
05-29-2021 06:29 PM
R50/53 More supercharger hulabaloo
one73ronin
23
09-22-2015 09:56 AM
