R55 RSB setting
RSB setting
I am taking Zippy to Mini Thunder III. My question is this.....I have the Alta 22mm RSB. It's currently on the softest setting.
1 Should I start the track day in the middle setting?
2 Leave it on soft and see if it pushes then move it up.
3 Or start on the stiff setting because you have used this RSB on a track and that is where it needs to be?
Anyone have tire pressure recommendations? Stock RFTs with 10K miles. The car came with 205/45/17
I am thinking moderate tire pressure to be 30 lbs??? We only have five 21 minute sessions. I don't want to make multiple changes between sessions but I may be forced to based on how bad it pushes. It pushed with the stock RSB but I haven't seen that since I installed the 22mm RSB. I have driven it pretty hard on Hwy1 (Golden Gate Bridge north to Jenner) and no push there but it's not the Nurmberg Ring or a track so I am sure things will be different on a track. I didn't think of adding air pressure to just the rear tires so thank you, great tip.
If it just will not turn I will take the advice of the pro from the ring and set it to full stiff.
what would be the disadvantage of going full stiff setting? I know it's likely to cause a loose condition but would it be undriveable? or would it cause the handling to go to a "razor edge" set-up between grip and loose?
Throttle lift oversteer can occur depending on tire grip and weight transfer.
Undriveable? No. Twitchy, maybe. But you should be able to compensate with technique before getting in and switching settings.
No, it's similar to predict and feel as you progress.
I'm still an advocate of starting soft and working up as you modulate tire pressures and heat into the tires/ track.
- Erik
- Erik
Back from Mini Thunder III. This was a great time. The event was organized, safe, fast, and fun for all--beginner to expert. This one will be on my calendar for next year.
I ran the advanced class based on my prior driving experience. By the third session I had the track down and was up to speed. They had coaches available so I used one to help learn the track.
Erik, Thanks, I used your advice, started on the softest setting and never changed it. I did lower the air pressure. 30 lbs hot in the rear ended up being the best. But it took several laps to heat back up to the hot setting. Looking back, maybe 28 cold would have been best and would have come off track about two lbs high, a good balance. The rear was loose on weight transfer, throttle lift and I think if I stiffened the RSB it would have gone the wrong way.
Funny thing is, I was worried it would push, it never really understeered but the back wanted to come out quite a bit. With that said, I am more than impressed with the performance of this basically stock car.
If you haven't already, keep a log of your track days, settings, pressures and the like.
You'll learn a lot in terms of vehicle set-up and preparation for your next time out.
- Erik
