I'm coming up on 25,000 miles on my Clubman and looking at replacing my runflats tires. Planning on going with non-runflat Continential DWS and upsizing to 215/45-17's. Does anyone have any pictures of their Clubman with this size tire installed?
I just put 205/50/17 on my clubman. I wanted a little more sidewall hoping it would make it ride smoother. Had them on for 1 day , no issues yet and they ride pretty good.
I have had both the Conti DWS tires and the Kuhmo 215/45/17's on various MINI's. IMHO the ride is much better than stock. Never had any issues with either.
With the 2-4MPH error in the MINI Speedo to begin with it should cancel most of it out. But there is the possibility that it will still make you car slightly faster than what the speed states. The average change from a 205/45-17 to a 205/50-17 is 2 mph faster for the car at the same speedo reading.
I've had the same, no issues at all......and I like the looks better.
Just put 205-50-17 on my Mini. No problems and I have a much better ride especially compare to the original 205/45-17 run flats. I went to 50 series in hopes it would improve the ride.
Speedometer reads about 2 miles faster than what my GPS reads. I will be checking the gas mileage as I go to see how it effected MPG.
Thank you t0 Big Jim Swade for starting this thread. I think I will have to with 215-45-17 and would like to see the rear view if the tires do not stick out too far.
The reason I wanted to upsize is to partially correct the speedometer error an also have a little wider tires to protect the side of the rim when my GF parallell parks!
Not a rear view, but you can see how much they stick out - are you running stock wheels?
