R55 RIMS for 2008 Clubman
Hi,
I just got a red 2008 Clubman base model this week. I know I will have to replace two of the tires by winter. I want to get black rims for it. I have two request:
1. What size rim fits? Also, if I wanted to get bigger rims/tires, what size combo works that won't rub and will clear properly?
2. Can those that have black rims post a pic?
Thank you in advance for those that respond.
Melinda
Melinda
On the base-model Clubman, a 15"-18" diameter wheel fit.
That's a loaded question; when you say "bigger tires", do you larger side wall (which causes larger overall tire diameter) or larger wheel diameter?
- Erik
- Erik
on
1 Post
Welcome to NAM! Looking for wheels can be a long-term commitment. I'm on my third set of aftermarket wheels and finally found what I wanted. You may want to peruse through TireRack and select your MINI as your vehicle and then refine the search by choosing black as your finish. You can even look at them on your MINI.
You'll get all kinds of opinions on wheels - here's mine. 17" wheels are the sweet spot for size. 16's are an awful lot of rubber and 18's can be an issue with rough roads - not enough rubber to protect the wheel from damage.
Here are my Enkei Imola's:
Note, If you're looking for specifically for winter tires, a smaller wheel diameter like 15" or 16" allows for more cost effective snow tires.
Once you get into the 17"+ range, they can become quite pricey quickly.
CO Springs is still a mess on the western still with the Waldo Canyon fire; the rebuild process has only just begun.
- Erik
Thank you all for your thoughts on this. I'm looking at Tirerack now and will go with the 17's that you suggested. The car currently has run flats on it and I'm thinking of keeping run flats. I don't dislike them they way a lot of people seem to.
Of course, then the issue will be what tire to get!! I'll post once I decide on the tire. If you've got thoughts or suggestions on tire brands please let me know. My friend suggested a "low profile" tire that will fit the 17" but what size does that represent?
Melinda
Melinda
I would say stick with 17"s. They are the perfect compromise between looking good and driving good.
The RFs are a good option if you commute a long way every day. But I promise you that once you drive with regular tires the car just feels so much better. Even on just normal performing regular tires you can feel the difference in grip and comfort.
Tirerack is a great guide. There are plenty of low-cost options that perform really nicely on the MINI. If you call TR directly they can more specifically compare the tires for you at the price level you are looking at (treadwear, season, etc.)
Melinda
Melinda
+1 to Mini///M's recommendation on Tire Rack. Here is their guide to tire sizes.
Well, I called tire rack today and found out that if I'm going to keep my run flats that they do not come in the 215. So, I'd have to stay with the 205's. I'm still trying to figure out which rims I want. It's apparently become my new obsession. LOL Great..something else to be OCD about. I should know by next week what I'm getting and I'll post it with pics.
Thanks again for all your help and pics!!
Here's my '10 S with JCW R113's. They're 18". They look awesome, but only 3 days after i bought the car, i hit a pothole and bent the outside lip. Had to get it fixed :(
They're a little stiff and noisy on crappy roads, but they look really nice. I drive 35 miles to work one way on a daily basis on SoCal roads/freeways and it's not too bad, but if i had to make a recommendation, i'd recommend 17's has the largest you should go.
Hi,
Melinda
Melinda
