R55 DANG IT! Carbon buildup...
Welp, had the engine light on my '09 Clubman S. My regular (indie) mechanic informed me it's low compression probably due to carbon buildup. Did a once over to make sure nothing else was causing it, and after talking with my dad (the previous owner of the car) this is the second time carbon has slowed it down. First time at around 20,000 miles, now at 53,000 miles. Will be getting the estimate later today. I'm sure I'll need a drink afterward.
So after scouring message boards and internet tales of BMW woe, I've found only a handful of things that may possibly help to avoid this buildup in the future. Firstly, apparently I need to "drive it like I stole it" which, for anyone in Los Angeles is damn near impossible in day-to-day traffic.
Secondly I've read positive things about the oil catch can, and thirdly the methanol/water injection systems.
Can anyone enlighten me on whether any of these will make a difference with the carbon issue? Are there others that I'm missing? I find it absolutely ridiculous that this wouldn't be covered for the life of the engine, since, well... it will apparently keep happening for the life of the engine.
Im not sure if its the same where you are but i know i got a 4 year warranty on my 2010 clubman s and the dealership even told me, after i asked, that they would do the carbon removal process no charge because my car is still covered by warranty. So ask your dealership if they will do it if you still are under warranty.
I've been fortunate in that my car has 50k miles on in it, and I've yet to need a carbon cleaning. In all honesty, I think periodic cleanings are inevitable with direct injection engines and will soon become a regular maintenance item with cars that have it. I think their attempts at fixing it have been band-aid solutions at best. The good news is the price of a cleaning has dropped drastically, and you should know it pays to shop around for it. Don't settle on one source, because there are independant shops and even dealers that can do the same thing via the walnut blasting technique for much cheaper. Good luck and let us know how it turns out.
I know Defenders of Speed sell a seafoam kit that supposedly removed carbon build up. However it's only ships via ups ground i think because they dont want to risk the can with the foam exploding if it was in the air (as in fed ex or ups air). And as for the band-aid solutions, the only one i've seen would probably be an Oil Catch Can but i've seen from plenty of posts that they are only useful if installed correctly.
My car has just over 50K and the light hasn't come on, but I pulled the intake off and OMG were they encrusted with carbon.
I don't think driving it hard helps as my car gets tracked several times a year. I also have yet to see any convincing evidence that catch cans or seafoam makes a lick of difference.
I built my own carbon blaster and one of these days soon I'm going to go after it and see how much difference it makes, but I consider it a maintenance item anymore, similar to RobtJ.
If you haven't pulled the intake manifold off to look, how do you know whether you have a buildup or not? Just because you haven't gotten a check engine light?
Yup, Chevron supreme every time, and I take a good 7 hour drive up to SF about once a month. I think the problem lies in my daily drive to work. 7 miles round trip on surface streets just doesn't allow for aggressive driving. Makes me sad, because I do enjoy my drive to work in Old Pepperwood- even if it is under 25 minutes each way. At this point I'm considering getting a cheap motorcycle for the weekday driving and save the MINI for when I can give the tach a little workout.
Just before the CE light went on I had noticed a drop in fuel efficiency, followed by a very slight rough idle and a little less pep in my step. I probably would have taken it in eventually anyway. I'm down a couple grand at this point. Hopefully it'll drive like new for a while once I get it back beginning of next week.
Thanks to all who chimed in!
Like I said, not really sure what I was looking at, but my guess is what's in the cylinders is part of the cleaning?? I asked about the rings, he said absolutely no problems with cylinders, etc. The main concern for him was the thickness of the carbon buildup around the valves. Expected from a car with 150k miles, but not 53k- and this is the second time it's been cleaned off!
So I wonder how we R56 owners are supposed to deal with this issue properly and efficiently. Do we just wait until the CE light goes on? Is there a way, short of pulling the valve cover, to know when you need to bring it in for the walnut shell blast? Or do we just trade it in for a '11 or newer? I hear they fixed this problem to an extent after '11?
great pictures! Wow that is a lot of buildup when compared with non-direct injection cars! Even my 200K+ miles honda doesnt look that bad! This is a design flaw for the R56 and will be part of regular maintenenace to keep the car running well if you decide to keep it. KNowing that bit of info, you might be better off getting a newer model, but it might be too early to tell if MINI has indeed fixed the buildup issue.
At least we're not seeing any horror stories post 2011 about carbon in the S models.
