R55 Can't get wheels off
Old 11-20-2013, 06:36 AM
Helix13mini's Avatar
Helix13mini
Helix13mini is offline
There's a bunch of good advice above. One thing to be sure of is that you're clear of the car when beating the hell out of it: you don't want it falling on your legs! Always be careful when laying a beating on something.
I know, I'm going to hell
  #27
Old 11-20-2013, 07:48 AM
srmitch2's Avatar
srmitch2
srmitch2 is offline
$39.95 for a tire rotation, they'll get 'er done.
  #28
Old 11-25-2013, 07:06 PM
Flyinace2000's Avatar
Flyinace2000
Flyinace2000 is offline
Originally Posted by cristo
Can also try this:
Loosen all 4 lug nuts a little (1-2 full turns at the most).
Drive the car back and forth a little a few times at the curbside or
driveway, stopping very sharply; do this with the wheels turned at least a little.
This will often break the seal between the hub and the wheel.
Don't do this, fail, and give up and go on to drive the car normally without
re-tightening the lug nuts, or you could be in for a nasty surprise.
This method has worked for me in the past when all else has failed.
  #29
Old 11-28-2013, 12:46 PM
UH60Hwkdrvr's Avatar
UH60Hwkdrvr
UH60Hwkdrvr is offline
Originally Posted by jkapinos
Can also try this:
This is the solution.
Mike
  #30
Old 11-28-2013, 08:11 PM
CarlosDMotor's Avatar
CarlosDMotor
CarlosDMotor is offline
If you can kick your car off of jack stands you must have some insane legs or your car isn't supported properly. Very unlikely it's the former
  #31
Old 12-19-2013, 07:31 PM
Jandreu's Avatar
Jandreu
Jandreu is offline
Well I finally got around to rotating the tires. I picked up a good spray penetrating lube and sprayed the area between the wheel and disc well, let sit for 6 hours. Two wheels came off without much trouble the other two still would not move so I put the lugs back in but left them loose two turns, drove the car back and forth a few times hitting the brakes hard. Both wheels came off but were still very tight. All 4 wheels had a lot of rust around the hubs. I lobbed everything with white lithium grease and put the tires back on. Should be go to go for the next rotation.
barnoun
09-17-2018 05:04 PM
khumpert
11-30-2015 11:48 AM
SosoMINI
11-22-2015 03:17 PM
Tires, Wheels & Brakes
08-26-2015 11:02 AM
BowserKart
Tires, Wheels, & Brakes
08-20-2015 01:24 PM
Quick Reply: R55 Can't get wheels off
