R55 Burning oil
Pretty normal for many/most mini's.....
Some don't....
But about 1 quart per 1000 miles is pretty normal....
The blackish soot around the tail pipes are normal....
Mini's are tuned to run a bit rich....
What you want to watch for is a SUDDEN CHANGE in the amount of oil burned...
But be sure to check your oil frequently.
Some don't....
The newer (2011-2013) may have lessened this oil consumption in the "S" models but the verdict is still out on those.
Hopefully the new (2014 and later) models without the "prince" engine will not have these problems, but again time will only tell how good these turn out to be.
I was thinking the same thing. I have an 09 s and burn maybe 1/4qt every 6,000 or more miles. I usually change the oil more often then recommended though, so I change around 6,000 or so.
Not everywhere has emissions tests. Washington doesn't unless you live in a couple of specific counties. When I was a kid, growing up in Oklahoma we used to have annual safety inspections, which included emissions, but about 10 years ago they did away with that. I remember all the trouble I had getting my 84' firebird to pass. Once I had to replace a windshield because of a 3" crack. Another time I had to replace a whole tail light cluster because of a bb size hole in it. It was ridiculous...glad they did away with it.
The kind of oil used can have an effect on consumption as well.
For instance, in an '08 Subaru Forester XT I had, Pennzoil Ultra 5W30 would be consumed like **** through a goose. Shell Rotella T6 had very little consumption over the course of the 3000-3500 miles between oil changes; maybe 1/2 quart. Royal Purple HPS showed no consumption.
In my '06 MCS JCW, I have about 3000 miles on the Royal Purple HPS 5W30. This is the first oil change I performed since taking ownership. The car has almost 70K miles. I have yet to add a drop since the changeover. I commute with this car easily logging 500 miles a week with 75% highway and 25% city driving.
Keep in mind that this has been my experience and your mileage may vary.
There are some threads on NAM about this issue, the cause of the issue is back pressure created by a small flow blockage in the catalytic converter that has been contaminated by oil. If you want to know why it is happening read the second section at the link http://www.jmturbocoopers.com/Cooper...ton-Issue.html. If you don't fix this issue you risk engine damage from oil getting into your intake system, inter-cooler, and combustion chamber. :(
07 S burned 1 quart of oil in 2k miles
gmonde
09-08-2015 06:37 AM
