R55 Check engine light with low fuel?
So my 2013 R55 has developed a 'weird' habit. Every tank of gas once it gets to the last 2-3 bars my check engine light comes on. When I called up my service advisor he said it was because the car was 'slurping' for gas in the reserve tank, possibly causing pinging in the engine, hence the check engine light. Once I fill the tank it goes away within the first few miles. My question is: Is this normal? Seems like a 'crying wolf' type of check engine light if it is. My gas gauge is red, the small display window has a gas pump icon, is the check engine light 'needed' for low fuel? I have had it, new from the dealership, for about 3 months now and it did not do this for the first two. It has only ever had Shell 91 octane fuel put through it, so I don't really believe when the service advisor says being low causes pinging in the engine, so I wanted to check with the community.
Hard to say about the SA's comment. There is one thing for sure though. MINIs do not like to 'slurp' fuel. There are many threads about running the tank down to near empty just to see if the owner's manual and OBC know what they are about. The results are disastrous with burned out fuel pumps and other nasties. Just a hint here, 'There are no old bold pilots' meaning old pilots always prefer to burn off the top half of the tank. Try not running yours down so far between visits to the pump and see does the problem go away.
is it true that you only have a gallon left when it's red at 2 bars? my computer tells me there's about 80 miles left though...
No, my closest Mini deal is ~60 miles away and I filled up my gas before I left. The light was on the whole way there, but as soon as I turned the car off in the service line it was off when he came to look. He said the techs didn't find any readable codes in the system.
Maybe next time put in just enough to get to the dealer instead of filling up since the problem seems to be triggered by a low fuel level?
So this has been happening on and off still. Thinking it was brand of gas specific. Seemed to not come on with Costco gas but it does with Shell or Chevron. I took it to get the code read today. Came up with P2068 'Fuel Level Sensor B Circuit High'.
Had a friend who was looking at cars to purchase ask me why my check engine light was already on in a 2013 car. Was a little embarrassed when even others are noticing it already. =/
07-16-2020 12:54 PM
truedrew
R60/R61 Stock Problems/Issues
08-10-2015 10:39 AM
