R55 Exhuast Smell In Cabin
Hello All, I bought a 2009 Clubby S one month ago with 35,000 miles on it. I love it! Only one problem..... When I hit higher speeds (and RPM's) an exhuast smell comes into the cabin. I have an appointment with the dealership next week and a warranty, but if I don't have to use either it would be great. What do you all think the smell is coming from?
FWIW, I get it sometimes.. when I really.. really get on the throttle...
Im at 12K miles, always use 93 octane fuel, car is well cared for etc..
My windows are generally down.. the sulfur smell can come from a few sources - mostly due to the small sulfur content in modern fuels.
http://www.epa.gov/otaq/fuels/gasoli...lfur/index.htm
If it only happens when you really push the car, its most likely normal as this is a common issue with many other makes and models. Sulfur is converted to hydrogen sulphide, this is "shocked loose" under wide open throttle and is picked up by your nose. Our bodies make hydrogen sulphide.. its what makes farts stink!
Why do you smell it inside the car? Well, there is an aerodynamic bubble formed behind the car. Exhaust gas gets swirled in the vortex and some is passed upwards into the wheel arch vent area - located in the rear of the body. While generally these vents allow a positive pressure inside the car, they can also become slightly negative under high speeds.
Some of that smell makes its way into the car, our noses are super, super sensitive to hydrogen sulphide.
This is also why the back of a hatchback gets so damn dirty!
What can you do?
Well, more frequent high speed blasts will prevent the buildup of hydrogen sulphide in the converter. Sometimes changing a fuel brand or grade will also help..
Again, this is not just a Mini issue, if you search for "rotten egg smell car" you'll see its quite common.
What can you do?
drrigg
05-27-2022 03:31 AM
dutchhome
09-30-2015 07:17 AM
silence2-38554
09-24-2015 05:34 AM
09-02-2015 09:05 AM
