R55 2009 R55 S. RPM fluctuation, is it coil problem?
This started to happen after I spilled on the engine, appx 2oz, during DIY oil change.
It only happens at the very first start up of the day even in this weather, 70-80F.
If I start her up while I step on the gas pedal and keep RPM at 1.5k -2k for 10-20 sec then it's ok. Even if I don't start with gas pedal stepped on it lasts only abt 30 sec then everything runs fine. OBD shows it's misfire in cylinder 1,2,3,4. Can oil spillage cause this misfire? It's never happened before this oil mass. Apparently oil did not smear into any of cylinders. One of the tech says it's coils that causing this problem/misfire.
my question is; can oil spillage cause misfire? How? Should I just get coils replaced?
