R55 Sport Mode?
Old 08-07-2014, 09:36 AM
StuSegal's Avatar
StuSegal
StuSegal is offline
Sport Mode?
I have a '14 Clubman, automatic.
What I expected when I put it in Sport mode was for the shift points to change. But it feels like more than that—it feels like throttle response is remapped to be quicker, shift points have been raised, and maybe something else.
Anyone know exactly what Sport mode does? (And, ps, the salesman told me he always drives his in Sport mode, and the fuel economy is unaffected, which I really doubt.)
Thanks . . . Stu
Old 08-07-2014, 09:52 AM
MontyRSVR's Avatar
MontyRSVR
MontyRSVR is offline
Quick throttle response , steering a bit quicker and I don't have an auto but I suspect the shifting would change.
Old 08-07-2014, 10:21 AM
fastfour's Avatar
fastfour
fastfour is offline
It definitely tightens up the steering. I have a manual so I can't comment on what it does for autos. Throttle response is increased. I don't notice a hit on mileage unless you keep your foot in it. Hwy cruising mileage is unaffected for me when in sport.
Old 08-07-2014, 12:24 PM
bmwr606's Avatar
bmwr606
bmwr606 is offline
the sport button does
1) makes the steering harder by reducing the amount of assist, no change to ratio
2) enables the "pop and burrble"
3) changes the relationship between the gas pedal and throttle plate so just a small movement of the gas pedal results in large throttle plate movement
4)on auto trannies, raises the shift points, both up and down and will hold a gear when you lift throttle instead of immediately upshifting
it does not make more hp or torque and therefor does not increase fuel consumption nor does it change any suspension settings
Old 08-07-2014, 12:46 PM
cerenkov's Avatar
cerenkov
cerenkov is offline
On the 2013+ "S" models it also maintain engine coolant temperature at 175F instead of 220F
Old 08-07-2014, 01:04 PM
Grizld700's Avatar
Grizld700
Grizld700 is offline
This is one of the many things I wish I had in my car, it sure would be nice to have when I'm autoXing.
Old 08-07-2014, 04:23 PM
bmwr606's Avatar
bmwr606
bmwr606 is offline
my 2012 drops coolant temp if I run over 4000 rpm or turn on the A/C
the sport button does not lower the coolant temp
Old 08-07-2014, 05:59 PM
mini coop's Avatar
mini coop
mini coop is offline
Makes it more fun to drive. 'Nough said.
Old 08-08-2014, 07:33 AM
Grizld700's Avatar
Grizld700
Originally Posted by bmwr606
my 2012....
...the sport button does not lower the coolant temp
Was this just to confirm your '12 sport button doesn't drop the coolant temp? Just checking, because it has been verified by a couple people that in a '13 the coolant temp does drop.
Old 08-08-2014, 07:59 AM
rckrzy1's Avatar
rckrzy1
rckrzy1 is offline
you folks are trying to tell me driving in sport mode at say 35mph @3K is gonna be the same mpg at 35mph @1800 ? I don't think so on the autos.
In sport mode it stays at higher rpm till 38/39 mph and it can't be the same mpg
Once you get to about 70 and it's in top gear then I buy it.
Old 08-08-2014, 08:18 AM
cerenkov's Avatar
cerenkov
cerenkov is offline
I couldn't care less about mpg. If I did I would have bought a Prius.
Old 08-08-2014, 09:18 AM
Grizld700's Avatar
Grizld700
+1 . With my tune I'm running around 27mpg. I could care less.
Old 08-08-2014, 10:02 AM
ashchuckton's Avatar
ashchuckton
ashchuckton is offline
^^^ This is true.
I care about fuel mileage, but care about having fun driving more.
Old 08-08-2014, 10:30 AM
jcauseyfd's Avatar
jcauseyfd
jcauseyfd is offline
Right, on the autos fuel efficiency will be impacted due to the changes in shift points.
Old 08-08-2014, 09:37 PM
hamptup's Avatar
hamptup
hamptup is offline
Your driving habits will dictate fuel consumption in either mode. Personally I prefer to always drive it in sport mode especially around town. Best way to describe it is the car drives with a little more pep!
Old 08-08-2014, 10:44 PM
a2oc's Avatar
a2oc
a2oc is offline
It gives u more torque when WOT, coz overboost function is on. If you drive with sport mode D, it seems to shift like a dream (quick and crisp), and if you are light foot enough, it will shift at ~2.5k rpm and less likely to seek highest gear (in normal mode, it will shift to 6th at 40ish @1.5k rpm, waste of the potential of the N18 :( )
Old 08-09-2014, 12:42 AM
yesti's Avatar
yesti
yesti is offline
Thanks . . . Stu
You can watch real time mpg drop when switching to sport mode while cruising at a constant speed when the tranny downshifts. Kind of buzzy on the freeway but a blast to drive in the city.
Old 08-09-2014, 08:14 AM
fastfour's Avatar
fastfour
fastfour is offline
Are ya'll able to monitor coolant temps via the on board computer or are you using plug in diagnostics?
Old 08-09-2014, 03:37 PM
yesti's Avatar
yesti
yesti is offline
I have the optional JCW gauges (coolant temp/relative torque). You can use scangauge or other ODB2 to monitor.
Old 08-11-2014, 02:47 PM
Ian Fraser's Avatar
Ian Fraser
Ian Fraser is offline
We had a guy on a MINI run over heat his auto because he left it in Sport on the open road. Sport locks out the automatic shift to 6th so you will need to put it in 6th manually.
Old 08-11-2014, 04:43 PM
bmwr606's Avatar
bmwr606
bmwr606 is offline
I call bull **** ...
I run sport mode ALL THE TIME and often run in 4th gear at 75 mph+ ... no overheating
look for another issue causing the overheating ... it is NOT being in sport mode
Old 08-11-2014, 04:45 PM
bmwr606's Avatar
bmwr606
bmwr606 is offline
overboost is NOT a function of having sport mode on, it is always available
Old 08-11-2014, 04:50 PM
Ian Fraser's Avatar
Ian Fraser
I should have been more clear.
It was a Gearbox Overtemp warning. He didn't know 6th was locked out in Sports mode. We had been at highway speeds for a while before it happened.
From that point he mamaully shifted it to 6th and no more gearbox overtemps.
Old 08-11-2014, 06:21 PM
bmwr606's Avatar
bmwr606
bmwr606 is offline
scan gauge 2 ... oil temp, coolant temp, engine temp (not sure exactly what this is but it is different than the oil and coolant temps), intake air temp (after intercooler), if you have an automatic transmission it will display it's temp too
Old 08-11-2014, 11:33 PM
yesti's Avatar
yesti
yesti is offline
If he was cruising leisurely enough that the engine was running in "boiling hot 105+ C mode" that would add heat to the tranny indeed.
Quick Reply: R55 Sport Mode?
