R55 JCW Aero II Kit and Back up Sensors
There are JCW Aero II kits that have the PDC holes and some dont ( without PDC ). If you have without and you have them on the Clubman already , you will have to drill / mod for the upper center holes , They lower tims you can get new parts with the holes or drill / mod also.
Without PDC
With PDC
Without PDC
With PDC
You will need the conversion kit 4 for MY 8/2010-3/2012 also. If you get the 2008-8/2010 kits.
No High Class Grey in the Sale kits prepainted. Just primed versions.
What year do you have , looks like a 2012 ? The coversion 4 and the older -8/2010 kits work up to 3/2012. Check your production month/year. For 3/2012+ newer i don't know if the older kits will work .
Yea, I dont know anyone who has put the older kit on a post 3/2012 . I know allot is similiar but its under the bumper ( brakets ) that might have changed. Across the board 3/2012 the JCW body kits changed.
3/2012+ kit
http://www.ecstuning.com/Search/SiteSearch/51952297908/
Then you get the front and rear bumper separate, trim covers, carrier, MINI changed how the kit was done for 3/2012+ , not in all in one kit. Also if you have PDC or not.
I guess they streamlined shared parts.
Let me know if you still want the JCW 3/2012+ body kit. Its still very nice.
3/2012+ kit
The 3/2012+ kit will fit your MINI R55 . Its the older kits => newer 3/2012+ MINI R55 I am not sure will work.
3/2012+ kit
3/2012+ kit
Good luck, let us know how it goes and if you need any extra factory parts.
On the bumper the top portion is the same as the JCW and NON JCW , that holds the plate lights ? This part you reuse with the new kit. Take some pics , very confused here.
Clubman S
Clubman NON S
Clubman S
Clubman NON S
The lic plate lights should be in the same location the top portion of the Bumper is reused with the JCW bottom half ? Also the rear plate bracket is here, it for some reason does not come with the kit.
Just states in conjunction with this. Does not state the plate on the install pdf. Which s the plate holder.
http://www.ecstuning.com/Search/SiteSearch/51187160607/
So it must be shelf tapping screws into the center of the bumper plastic. Then reuse the four plate screws.
07-16-2020 12:54 PM
12-23-2015 10:36 AM
