R55 Loose 6spd shifter
Loose 6spd shifter
'08 Justa 6spd. No problems shifting but when my wife drives, she somehow pulls up on the shift **** and the shaft dislocates and then can rotate. I look down and see the shift boot twisted, the **** numbers upside down and have a kniption . I can't find a pic at realoem or a thread on NAM to fix this.
Shifter lug : 25112753810
https://www.ecstuning.com/Search/Sit...53810/ES47116/
Twist it back, make sure the bottom **** odes not op off the cable. the top nylon tab might need lifted a hair to spin the round pivot ball back.
Reach it from the top , the nylon piece snaps in and holds the ball in place,.
One the boot trim ring , you have to work around the base of the boot
https://www.northamericanmotoring.co...ob-w-boot.html
Yea, its a little bit of work, try the trim tool:
https://www.ecstuning.com/Search/SiteSearch/Schwaben_Trim_Tools/
ok, well when i did the JCW shift **** upgrade i used the thin one and worked it up from the sides. Then it came out. Try a really flat tiny screw driver to help pry it up, push it down in the seam first a bit and tap it down.
ok, let me know. Here to help.
Finally got it! Made initial ingress with a razor knife, then a tiny flat blade screwdriver on either side of it. Did some gentle prying and finally got it unclipped.
It turned out it was the **** that was loose, the only thing keeping it from coming all the off was the boot. Got it put back together - good tap with a soft blow hammer and all is good.
Yesss, awesome. I knew you could do it.
You are welcome. Thanks I appreciate it.
deschodt
03-31-2016 12:37 PM
