R55 New mini owner, engine noise question, video...
Hi everyone. First time mini owner. I've wanted one for a long time and the opportunity finally arrived to buy one. I bought a 2008 Mini Cooper clubman s. It has about 84k on it and it is in fantastic shape. This morning I replaced a leaking valve cover gasket and also took the opportunity to inspect the timing chain. All appears good. I've also done a fresh oil and filter change, new air and cabin filters, water pump with new coolant and new drive belt. The car runs great!
However, I noticed this morning that there is a knocking noise at idle from the engine. A friend of mine who is familiar with engines thinks it's a normal noise for this engine.
So I took a video for all of you to listen and I'm looking for opinions. Keep in mind, no check engine light and it runs and drives great.
Video...
http://vid675.photobucket.com/albums...pso2tpwzlw.mp4
Video...
I am not an expert. Please get other opinions before you take action. Since no one has posted: Sounds like death rattle, timing chain/tensioners about the fail and destroy your engine. You can search this site for more information "death rattle". I would not drive it until a mechanic that knows the MINI looks it over.
Good luck!
Good luck!
guiltless
05-05-2016 12:59 PM
