R55 Vacuum Pump Bolts size (Help!)
Hi Everyone,
My wife just purchased a 2009 Mini Clubman, and I'm doing a lot of repairs this weekend. Water pump, Oil filter housing seals, valve cover, plugs. I carefully bagged and labeled all the fasteners as I removed them because I a new to Mini.
I doing the re-assemble and I can't find the bolts for vacuum pump. I either misplaced the bag, or accidentally mixed them with some other fasteners.
Does anyone know what size bolts hold vacuum pump?
Thanks in advance,
Lou
Thanks in advance,
Lou
Nik,
Thanks for the help. I determined the bolts are M6x25 from the link you posted. I believe the original bolts have 8mm heads, but I couldn't find these at local parts store. I used cap head M6x25 with 10mm heads. Hopefully this will be trouble free, but I can always order the correct part it the vacuum pump leaks.
Thanks Again,
Lou
Thanks Again,
Lou
Nik,
Thanks Again,
Lou
Thanks Again,
Lou
soggybacon
R55 :: Clubman Talk (2008+)
06-23-2018 05:41 PM
