R55 Losing Antifreeze
Losing Antifreeze
Engine light came on and the code reader (I forget the number) said it wasn't warming up fast enough. Now it's needing antifreeze every few days. Just looking at other threads here I see pressure leaks are somewhat common, my car does not leave any antifreeze on the ground so I was thinking head gasket, but my exhaust pipe looks exactly like it always did. So where do we start the investigation?
When I saw the code I got out my book (service manual) and read something about the thermostat being heated by electric. Reading that made me think I should sell the car, sounded crazy & I decided to forget about it - until this came up. Guess I'll do a pressure test, but what's the deal with an electric thermostat??
I already got back from NAPA before I saw this! The t-stat housing is now in (twice) had trouble with the so called water pipe not going all the way together. It's so hard to see and work with I thought I had it right only to have a bad leak. Second time, after complete removal to check for damage, I got it right. I now have a short test ride done and it seems ok, will know better after some longer rides~ Thanks for the help, that's a nasty job!!!
bugeye1031 (06-26-2021)
For future reference, always lube o-rings. You only need a greasy film, no goobers! That might have made it a bit easier.
In a cooling system either o-ring grease or silicone grease will do. I guess you could use Syl-Glide in a pinch and it should be compatible with coolant and the o-ring material.
I'm grateful your tstat failed as it made me realize that my 2013 is far past due for water pipe / tstat preventative replacement after 8 years of service!
Likely totally unnecessary, but it won't hurt to double check that all the air is out of the system.
Second test ride made the water in the canister disappear, when I started to remove the cap, it all came back, so I'm thinking I have trapped air. Just glad the old 3.0CS is running good, but I better renew the reg. The Mini book doesn't have much on purging the system. They say to turn on the heat, strangely also the seat heater which I thought was electric, and to remove the cap and run it. Then if that doesn't work to use some kind of vacuum tool (not their wording). So, the basic question, is there some trick to get the air out?
I had my bleeder open till I saw water then let the temp get up to 220 keeping the reservoir at the full level. My heater was on but wasn’t hot enough, so I kept the bleeder open till it got got and topped off reservoir. Project mini has a good one for bleeding coolant on you tube. I think it’s in the how to section as well.
The vacuum tool is awesome for filling the coolant. A little expensive, but totally worth it.
https://www.ecstuning.com/b-schwaben...l/003466sch01/
ECSTuning (06-25-2021)
R50/53 Should I replace the head?
quickslvr580
05-14-2013 03:37 PM
