R55 uneven pad wear on new install of rear brakes
Hi all,
Installed new pads (TRW) and new rotors (EBC) two days ago, on a 2008 Clubman (base, non-s) with 170k miles.
Photo of driver side rear rotor shows nice and even pad contact on the rotor (coated in black, so it's easy to see)
Photo of passenger side shows obvious difference in pad contact.
Anyone know what I need to do to correct this?
Thanks in advance.
Thanks in advance.
I was thinking the same thing, but the previous pads wore unevenly as well. I'm wondering if something fundamental is bent / out of whack. Hub, or caliper? I will strip it down again and see what I might be able to find.
I did lube the guide pins, the pads and use disc brake quiet on the contact points to the pads.
Thank you for the reply.
If you did the work, I would suggest getting back in there and seeing if anything looks out. If a shop did the work, I would be taking it back and having them make sure it was all put together correctly. From the picture, something isn’t right. But also from the picture, can’t tell what’s wrong….
Hi - I'm in the middle of replacing rear calipers on a 2007 R55 that was wearing the outside pad on the RH side of the car unevenly (that pad 3mm, inner pad 9mm). Normally the inner pad wears more than the outer. The caliper piston on the RH one is sticking such that once the handbrake (ebrake for you guys?) is released there's still contact on the rotor. My initial thought was sliders were sticking but they are fine and the piston cannot be retracted. In this situation you may see one wheel gets a good covering of black brake dust (and/or one rotor/hub heats up quickly on a short drive from cold).
This may account for the original problem but not the lack of wear in your picture?
One other thought - check that the 'legs' or 'ears' on the new pads are not carrying an excessive amount of black paint/plastic/whatever - sometimes that can cause them to stick in the stainless steel carriers, a quick file/sand can help if they are.
Piston R&R is not that hard - use the brake lever on the caliper back to jack the piston out.
Piston can be screwed in with special tool. I think Pelican has a "how to" that shows this.
A piston that will not retract is usually caused by an old seal and/or boot. You need to either get a rebuilt/new caliper or pull the piston out of yours and replace the boot and piston seal. Scrape the grooves for the boot and piston seal until they are completely free of corrosion. Make sure both boot and seal are lubed with brake lube (SIL-Glyde for example).
I have two 'specialist' caliper retraction kits one is for van/light trucks - but to be honest I've usually managed cars with just a pair of needle nosed pliers and if the heavy duty 'winder inner' is needed then it is usually an indicator that the piston or handbrake mechanism is in need of some TLC - you can bet your bottom dollar that if a hard 'wind' is needed to get the piston rewound then the next pad change will involve a refurb.
Pretty severe uneven wear. Did you make sure the pins slid easily in their holes? Did the pads fit easily in their seats? Does the parking brake mechanism on caliper retract properly after released? Does it look like the pad is sitting flat on the rotor?
When we serviced the brakes on my son's MINI after noticing uneven wear (and too much heat) we found the parking brake wasn't releasing, the internal parking brake mechanism in the caliper had seized up from corrosion. Another time we found some white corrosion caked up between the hole in the carrier and the rubber bushing. We had to file that stuff out before the guide pin would move freely.
DaveTinNY
26
09-01-2008 06:38 AM
