R55 No start issue
No start issue
Hi, everyone.
So i've been trying to hunt down a reason why my clubby won't start, and I'm curious if i should be looking at the infamous fuse pump relay that has seemed to be an issue with most.
In the beginning when i first bought the car it ran fine. first time i really drove it for a distance it stalled several times. So I went to through motions to narrow it down. Changed the in tank filter, low pressure fuel pump, high pressure fuel pump, fuel pressure sensor. So my latest step was i purchased an OEM used sending unit put a new filter in that as well as a fuel pump. It was good deal for two fairly low mileage parts (60k). The last thing i did today was loosen the metal line from the HPFP to the rail to see if i would get a spray. Nothing and even went as far almost disconnecting it entirely. Am I safe to say that the relay thats soldered on to the stacked fuse panel dead and or have a broken solder point? Any feedback would be fantastic.
s
s
b14nismo
08-28-2017 05:52 AM
