R55 Blow off valve?
Blow off valve?
So when I start my car in the morning it sounds like it’s sucking a lot of air then shuts off after a couple of seconds but the rpms are at like 1000 idk if it’s the blow off valve getting stuck then when it worms up it closes or a vacuum leak and befor the my car has been running a lil rough I have a 2014 r55
https://www.northamericanmotoring.co...ml#post4604574
Going from a "Stock" intake to an aftermarket 'open' element intake, you will hear different sounds. The stock intake is very good at muffling intake noises.
I get there will be new sounds but it’s like a fan is in there lol and when I push on the gas a little bit it stops till I release from the gas the sound comes back idk it’s like the blow off valve is stuck open and when I push on the gas it pushes it closed maybe idk I will take a video so you can hear it
I have the M7 intake and when its a little chilly outside and the cold start is running at around 1,300 rpm that thing is sucking a lot of air and it is crazy loud and then once it drops to 900 its back to sounding normal
R50/53 Bypass valve issue maybe?
Brandon Fluharty
11-14-2021 12:47 PM
